Home > Puma (Tdci) > ODB Port
adiep
Gibraltar 2008 Defender 110 Puma 2.4 SW Alpine White
ODB Port
Can anyone help with a picture to locate where this ODB port is? I have a LHD car and cant find it Sad
Post #287113 2nd Dec 2013 7:07pm
Lorryman100
It is under the steering wheel inside the fuse box. Undo the two plastic screws to remove the fusebox cover. The OBDII socket sits to the right of the fuses. Thumbs Up
Its the black plug to the right of the OBDII securing screw
Post #287120 2nd Dec 2013 7:16pm
adiep
oh thanks man ! will go and take a look !
Post #287121 2nd Dec 2013 7:17pm
adiep
I got it !! Thanks guys.. Seems ike i have an error code P1103 .. ho hummm
Post #287136 2nd Dec 2013 7:46pm
Cheshire110
FYI the BAS website (http://bellautoservices.co.uk/?s=P1103&search=Search) can be used to diagnose fault codes
P1103 = MAF(Mass air flow) sensor in range but higher than expected
interestingly i have that code come up once or twice a year on a long high speed run, dealer says its nothing major but 'keep an eye on it' as he said Cheers, David
Post #287158 2nd Dec 2013 8:28pm
