Home > Maintenance & Modifications > 200tdi x brake |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 |
I can't remember the answer to this
But I'd you download the fitting instructions, I'm pretty sure it tells you. All I remember is that I bought a different cable, from x-eng, that fitted onto my Td5. The distribution for x-eng products has been handed over to Foundry4x4 - so they are still getting used to things, but I expect they can sell you the right cable at the same time you buy the brake ? |
1st Dec 2013 9:28pm |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 762 |
Bigest issue I had with the X-Brake when I got mine was that the instructions were for an ealier version of the brake than the one I was sent (same goes for the on-line instructions which I have just checked and see that they are using the same old photos). It wasn't vastly different but it did make me think (for a moment) that I had been sent the wrong model however a call to Simon soon sorted this out. The caliper has been rotated slightly so it is closer to the O/S chassis-rail, also the cable bracket is different and has two holes not the single one shown.
Don't forget to get your 10% discount with Landywatch. ONE LIFE, GET IT! |
2nd Dec 2013 9:05am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
The cables are all the same at the lever end (in the cab), it's the brake end where the 200 & 300 differ.
2nd Dec 2013 10:29am |
