Home > Maintenance & Modifications > Defender fitting doubts on climair wind deflector!!
sherifsalem
Portugal 2005 Defender 90 Td5 ST Java Black
I was about to buy a set of Climair to fit it on my defender. Before placing my order i took a look on how they could fit and then i saw this clip beteween the windown housing and the metal door frame.
Couldnt figure how the wind deflector would fit in the window housing without removing this clip!?
your help is appreciated...
Che Happy Travel
www.thegippo.wordpress.com
Post #286903 1st Dec 2013 8:50pm
GUM97
Pretty sure they go behind the clip if my memory serves me correctly, but I didn't gain anything from having them fitted so they were binned! An engine to TDi for!
Post #286911 1st Dec 2013 9:04pm
sherifsalem
Thanx Gum, i hear so often it reduces visibilty but i was looking into it more of blocking the spray of rain when you need to open the windo to dimist....
So if the deflector sits behind the clip, what you ae saying the the delector has some kind os groove in order for the clip to sit in and the deflector come out... Happy Travel
Post #286917 1st Dec 2013 9:16pm
Myers
United Kingdom 2013 Defender 90 Puma 2.2 HT Epsom Green
Hi
They fit in the windows channel, the clip you have pictured doesn't get in the way, I've had them fitted to my TD5 and to m current Puma.
Some people like them, some hate them, I can't stand not having the window open and they do keep the spra and wind out.
Post #286925 1st Dec 2013 9:24pm
smb
If they are the genuine Climair then you have nothing to worry about as the Climair's moulded shape takes this clip into account and is moulded around it Thumbs Up
Post #286929 1st Dec 2013 9:28pm
sherifsalem
Thank you all it all clear for me know....
One last question is their any preferences between the Climair @ 37£ and the britpart DA6078 @ 29,50£( he later looks like it glues from the outside) Happy Travel
Post #286933 1st Dec 2013 9:40pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Correct.fit around clip, but do follow the instructions for fitting. Silicon spray is useful and ensure the deflectors are warmed up before fitting, to room temp as it makes it easier to bend them. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #286936 1st Dec 2013 9:43pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Snap Laughing
I found them to be a pita, reduced visibility and generally distracting when using side windows, sold mine on after a few months .. Guns and Landrovers .... anything else is irrelevant.
Post #286941 1st Dec 2013 9:48pm
sherifsalem
What worries me is that is that my eye vision is almost at the same height as the top door bar, i beleive most landy drivers experience the same.
does this become annoying with this reduced visibility? looking to the passenger side mirror do you get a clear vision? Happy Travel
Post #286953 1st Dec 2013 10:15pm
JWL
I had some on my Disco II and whilst they were good at keeping the spray off you when driving and the ability to leave the windows down slightly when parked and not get a wet seat in our British summers I must admit to being a little gratefull when the one fell off the drivers door. With the curve of the plastic it did make it a tadge strange to see through, being tall and wearing glasses compounded the effect. I will not be putting them on my Defender, I've lifted my seat and I'm looking through the top of the window, also as I greenlane a fair amount they will get scratched of that there is no doubt and would soon become an issue.
Just my view.
Post #286968 1st Dec 2013 11:04pm
Litch
Had them fitted for some time now and find them excellent, likewise my wife has a set on her Freelander and also likes them.
Yes they are moulded to fit around the clip.
Fitting takes a matter of a minute or so (I spent longer cleaning the glass & channel than it took to fit the deflectors).
They can be in the line of sight but I don't find it an issue as although they are smoked they are transparent. I found it more of a problem when I had a set of seat riser-rails fitted but these sat me too high for comfort (I was looking directly into the door-frame itself) so they were removed anyway. ONE LIFE, GET IT!
Post #286999 2nd Dec 2013 8:52am
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
i fitted them on the outer channel.
So you don't have a problem with that piece of wedge shape. that's there to help push the glass in while winding it up. try running down the highway at 70mph and putting up your powered windows without them. ask me how i know.
good :
you get to leave the window down slightly when parked under the hot sun
you get to roll down the windows about 1 inch even in Censored rain
you get enough air in when driving and not ruffle the fur of the wife / gf
bad :
the plastic in the channel does tend to crack due to that extra 2mm being wedged in between
vision of the PS mirror gets affected slightly, but it's ok
the curved on the top does affect vision when you are seated up high
but i'm happy with them. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
Post #288085 6th Dec 2013 5:20am
I fitted a pair of fronts and backs a couple of months ago, mine have a slight tint. Seem to work ok, my only criticism is at speed, the window seems to rattle against the stop when it's just open.
rear ones - perfect
Post #288093 6th Dec 2013 7:27am
bogwert
Scotland 2003 Defender 90 Td5 CSW Zambezi Silver
Re: Defender fitting doubts on climair wind deflector!!
Che
Sorry to drag up an old thread, but sherifsalem, did you fit these? Did you put them in the inside channel or the outside next to the door skin?
Post #576069 7th Nov 2016 4:50pm
sherifsalem
Hi Bogwert,
sorry mate cant help you on that as i have not fitted none of the 2 types. But i can recomend Climair have seen it fitted since then.
Since it was expensive it always was set as a second priority ...till now Thumbs Up Happy Travel
Post #576075 7th Nov 2016 5:18pm
