Home > For Sale & Wanted > [Wanted] Bulkhead spare wheel mount |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
As in the Land Rover one that allows you to mount your spare wheel to the back of the cab?
If so I will see if I can find my old one. Glyn |
28th Nov 2013 3:31pm |
Hock Member Since: 12 Sep 2011 Location: Yorkshire Posts: 131 |
Thats the one, someone must have removed mine at some point in time
28th Nov 2013 4:27pm |
I will see if I can find mine (removed about 4 years ago).
Glyn |
28th Nov 2013 4:42pm |
Thanks for having a look
28th Nov 2013 4:51pm |
Got one sorted
1st Dec 2013 4:44pm |
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 460 |
If your current one doesn't work out I think I've got one in my shed from my 90 hard top too. 2.2 90 XS
88" Series One Old Norton Minerva |
1st Dec 2013 8:23pm |
hhmmmffff......As I have 285's fitted on 16 inch rims the offset is too far out, which means the thread bar isn't long enough to reach the wheel
Anyone know of an extension you can buy or would I be best getting a piece welded on ? |
2nd Dec 2013 12:29pm |
Silly question but have you tried the wheel both ways around?
11th Dec 2013 4:46pm |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1717 |
Hi as above really
If you put it so the wheel faces straight forward it will go on. Only reason I know is have a 285 75 15 bf Goodrich all terrain on a boost (which is a wide tyre) and fits no problem with a lot of tread left? I take it your not still trying to use the alloy spacer between the bolt and galvanised holder. Cheers Tom Defender puma dormobile camper |
11th Dec 2013 5:55pm |
