Home > Puma (Tdci) > the good old manual choke... |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
I believe I'm not the only one to have suggested the engine seems to run smoother while cold and then once was the diesel know becomes more obvious.....
got me thinking - as we are now in an age of low emmissions etc could it be that while the engine is cold its fueled with a rich mix (like with the good old choke of petrol engines in an era gone by) and once warm the mixture is soo lean that it causes what sounds like 'pinking' / knocking noise all in the quest to reduce emmissions. so do the remaps we hear about where customers talk about 'it should have left the factory like this' a simple adjustment on the fuel mix plus a bit more in terms of additional perfomance..... (I use the word 'simple' very very losely and no offence intended). this is by no means a way of rubbishing the remaps because if the engine run better but uses a little more fuel I'm all for it. If driven right I believe an engine running well will be more economical than one that has had its fuel starved to within an inch of stalling. |
1st Dec 2013 11:27am |
Lm100
Always most helpful. Kind of what I thought however but I could never have put it together with so much detail. Presumably if the map was faulty it could lead to under fuelling in the same way a faulty MAF could result in over fuelling? |
1st Dec 2013 1:12pm |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 |
As I understand it:
The crankshaft is connected to the camshaft(s) by a belt. This determines the timing of the opening and closing of the valves. Today the can electronically monitor these shafts and change it bit to be mire efficient. So having a manual choke is rendered useless. A diesel needs air to breath. The more air the better is runs, hence why people with raised aur intakes mention a loss of a bit of power somethimes. Cold contracts material, also air, so this means more air is goung to the engine within the same volume. So when cold, yes your engine runs more exficient. |
1st Dec 2013 1:53pm |
