![]() | Home > Maintenance & Modifications > Locking the Diff on a Defender 90 |
dondiddy Member Since: 13 Nov 2012 Location: Hamilton Posts: 224 ![]() ![]() ![]() |
Hi there, The difflock mechanism can seize up if it has little use so don`t worry about it. If you keep working the lever side to side(gently) it should free off eventually and engage/disengage as it should. If its really stubborn you may have to peel back the gearlever rubber gaiter which should let you see into the top of the linkage. From there you can spray some releasing fluid like WD40 or similar to help free it off, working the lever side to side as you spray.Once its working its a good idea to keep things free and working to move the lever into low/difflock once in a while to stop things seizing up through lack of use.Hope this helps!
Norm4n Member Since: 31 Aug 2012 Location: Surrey Posts: 329 ![]() ![]() |
Sometimes mine takes about 5 seconds before the light comes on
Just be aware that even though you've pushed the lever across doesn't mean that it will mesh into diff-lock untill the gears are in line mhch as it will stay in lock when you pull the lever back untill the load is off the relevant gears allowing disengagement that's why it sometimes helps to reverse for a short distance perhaps going from lock to lock to help taking the load off the drivetrain.
Gwynne_90 Member Since: 29 Nov 2013 Location: Southampton Posts: 15 ![]() ![]() |
Thanks everyone. How much lateral movement should there be at the top of the transfer box gear stick _ I'm getting about 25mm?
It can vary between vehicles, the best thing for you to do is to get yourself on a patch of ground where you can actually find a feel for what your vehicle does. When the difflock lever is pushed across and it does not mesh into gear the movement of the lever may be minimal but if you keep a light pressure on the lever whilst driving you may find a further movement as the gears mesh. Just think of when you have the clutch depressed and go to engage first gear, you may find some resistance then the gearstick "slots" into place, though this is made easier on the main gearbox due to having synchromesh.
You just need to have a play around with your motor to see what's what. Perhaps a day or half day at an off-road site or you may be able to hook up with someone local to you to give you some pointers on how things work. |
