![]() | Home > Td5 > Exhaust |
Hi Jack,
Depends on how deep your pockets are? Several forum members (myself included) have Griffin exhausts. Stainless steel with lifetime warranty. They also do one for the TD5. Yes it has slip joints that the opposition will slate but if you want the best be prepared to pay upwards of £300 more for something that does the same thing. Pays your money takes your choice. By the way if you have a horse the maker of Griffin is an accomplished horse dentist, maybe you could negotiate a scrape and clean at the same time. ![]() ![]() http://www.defender2.net/forum/topic13619.html?highlight=griffin If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 663 ![]() ![]() |
I just bought stainless steel straight through front (non cat) and mid sections and used standard LR rear section. You can easily fit them yourself, takes about an hour as you have to drop the front crossmember to fit front section.
I also modified rear section exit for off road use, but this isn't necessary. It gives good sound, but not OTT. The two SS sections are readily available from a number of LR aftermarket suppliers and same with original LR rear section. Front about £70, mid about £55 and rear about £45. Cheers Steve |
