![]() | Home > Maintenance & Modifications > Security bonnet hinges |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 ![]() ![]() ![]() |
Al,
Yes, I've had mine for over a year and they are excellent. No sign of corrosion, but just be prepared for the extra weight when lifting the bonnet. Plus, with the right securing nuts they make it very secure. If you get a set then invest in a pair of lockable spinners ie the Thule ones then it is very awkward for the bonnet to be taken off and it secures your jack. |
ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517 ![]() ![]() ![]() |
cool...
stick them on the xmas list then ![]() have you got any pics, the site ones don't really show the jack fitted in a wide shot. |
Will do tomorrow when there is some light
Al,
Photos as req... The corrosion you see is from the HiLift. ![]() Click image to enlarge[/img] ![]() Click image to enlarge[/img] ![]() Click image to enlarge[/img] |
cheers...
are the nuts on the hinge pins standard or an extra? good idea having the bootie aswell |
The hinges came with 2 new bolts, 2 security nuts, 2 spacers and 6 nuts for hinges. The 6 bolts were fabricated into the base of the hinges. These bolts are quite long so you can put extra nuts on to tighten in pairs and isolated from the holding nuts. The jack extension brackets come with 4 Allen bolts and are very difficult to get access to especially when you've got a jack locked on.
If you get a set I would highly recommend you put a layer of marine quality sealant(silva flex 252i or equiv.) between the brackets and bonnet. |
