![]() | Home > Puma (Tdci) > Still with problems in high temps :cry: |
Eduardo Member Since: 28 Aug 2008 Location: Regi贸n Metropolitana Posts: 2110 ![]() ![]() ![]() |
Hi there!
Despite the change of the intercooler for a larger one and the new BAS remap I suffered again the problem of high temperatures and the safety management strategy. ![]() ![]() ![]() The problem happened during this weekend with temps near 30癈 with no more than 250 kg load (just 2 persons, 2 childs and the empty roof rack). We were in a uphill of approximately 12 km with an slope of 3 mt every 100 mt at speed between 110-120 kph. At the end of the slope the temp gauge goes up to the red zone very fast and the management strategy started. After few seconds we stop the car and the temperature come down very fast too (taking 5-10 second to goes up and goes down). Im concern now about what happens during the vacation period with the car fully loaded at high altitudes and towing our folding camper (1.5 ton). ![]() ![]() Any thougths about what can I check? Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 810 ![]() ![]() |
I would personally start from scratch and put everything back to standard and repeat the drive (test).
You need to reduce the number of variables and start a known base line. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
Ian,
Thanks for your prompt answer. This is an old history. The problem started time ago when I dont have installed the remap and the intercooler and the situation was the same: High temps at 110-120 km/hr under load (uphill or loaded) produce the cut off, Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Norm4n Member Since: 31 Aug 2012 Location: Surrey Posts: 329 ![]() ![]() |
So a 3% incline, ie gentle slope.
Do these cooling systems have a thermostat? |
What have you got in the way of diagnostic equipment - that can do live data?
Really for problems like this in the past I've thermocoupled vehicles up to trace what's the route cause.... I'd be very keen to look at actual water temps before and after radiator, themostat operation, oil temp, oil cooler in and out, air intake etc... and a couple of other things. I'd also look at coolant temp sensor. Changing the intercooler wouldn't change anything in my opinion as not an intake air temp problem. IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
Porny,
Thanks again. I have the typical Bluetooth ODBII reader with an android app that can store live data from the ECU (Torque pro). It is enough or I need something better to do the job? Thermocoupled the car can be more difficult but not impossible from here if I can get the rigth equipment and the cost is not prohivitive Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Change your thermostat
Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251 ![]() ![]() ![]() |
Do you keep your foot flat in 6th gear? Or do you change down to 5th on these climbs?
I've found that keeping the car in 6th on a long climb will increase the coolant temps to more than 96degC very quickly. Changing down to 5th then drops these coolant temps very rapidly. Aren't you pushing it to much in a "overdrive"/high gear? |
Thanks to all for the answers I have at least something to start.
In fact I use to drive in 6th all the way and probably that could be one of the reasons. On the other hand I made the same route several times before without any trouble. The problem appears 3 years ago in the Patagonia and from there appears randomly 4-5 times in a year (but always when is hot, at high speeds and with the car forced) Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge Last edited by Eduardo on 28th Nov 2013 11:58am. Edited 1 time in total |
What is this "radiator protection net" you mention in another thread?? Pov.spec,ftw. 2006, 110,TD5.
Jimbo,
I dont think so. This net is very open (thin wires with a separation of 3/4" and probably do not restrict the airflow more than 5%. ![]() MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
6th should only be used to cruise on level ground (and downhill). As soon as you hit an incline and the revs drop below 2000, you should gear down to 5th. Do you also monitor your EGT? That's one of the best ways to know when to hear down IMHO - whenever I tackle a hill, I keep one eye on the EGT and as soon as it shoots up I gear down and the EGT goes down as well. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
So basically the OP labours the engine in 6th, up an incline for circa 12 kilometers, and then wonders why it's hot!
Norm4an
I do this road several times in the past in almost the same conditions without this problem, for this reason I'm asking for help. Chhers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
