![]() | Home > Maintenance & Modifications > TD5 CSW Second Row Seats |
The centre frame supports the rear corners of the two outers so if you wanted to do away with it, you'd need to fabricate legs for the other two.
![]() Click image to enlarge It depends what you want in the middle though. It'd be easy to leave the centre seat out and fit a cubby box to the frame, for example. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
I fitted puma 110 2nd row seats to my td5 110 with minimal modifications
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
I want to do the same I also have an internal cage which restricts things aswell.
The below is expensive aswell. http://www.wmparts.de/index.php?option=com...Itemid=603 I am leaning to the Exmoor Premium ones x 2, but want to do a trial fit to see if they will suit. |
Marky Boy Member Since: 25 Oct 2013 Location: Maidenhead Posts: 96 ![]() ![]() |
Thanks for the posts, particularly like the WM Parts solution of the sub frame raising the seats higher, thanks Romadog thats given food for thought. When you think about it its easy to do and gives more leg room. Also improves the choice of seats.
Tiem to buy some box section and knock something up ! |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 ![]() ![]() |
Is this any use to you?
http://www.defender2.net/forum/topic13101.html It's stashed away not a million miles from you (near Aylesbury) let me know if interested! |
I have just come in from 3 hours in the garage knocking up a "prototype" and can see you have beaten me to it ! Thanks for the offer I will go down a similar route but only want two seats and as such will give it a miss unless all else fails. The plan I have is to start at the same height as the std 2nd row and build up the base with wood until I get the right balance between leg room and head height.
For me this is the way to go though, and cheers for the help. |
Marky Boy please show us pics of your efforts
