Home > Td5 > Td5 Genuine Rev Counter fitting doubts...
sherifsalem
Portugal 2005 Defender 90 Td5 ST Java Black
One more thing to fit in the Landy and this time it is a genuine td5 rev counter gauge. YAE100790.
I have checked most forums and therefore I would like to recapitulate and have your final say in this forum which I trust much.
I am now sure that I don’t have no Grey/white wire in the black plug, on pin number 19 I have an empty slot
I will use croytec wiring loom for that purpose, from one end is the pin that gets into the ECU black plug and works all it way to the dash board following the main loom trajectory.
Once this is set I will be moving the temp guage and the fuel guage accross, so that the rev counter could sit next to the speedo
Well my doubts are in the next step which is the 5 terminals on the REV
Live and Earth - For illumination, from the fuel gauge ( I will cut into the - & + wires from the fuel tank illumination)
Live and Earth - Ignition controlled, ( I will cut into the - & + wires from the fuel tank ignition )
Is this ok??
I will be doing the above because I read that I cannot use the positive of the clock because it is always live and that the negative can be used for earth, couldn’t make out what it the brown wire for in the clock?
The clock plug is unique I want to keep the plug for the center croytec pod system (will cut and make and extention)
Signal from ECU will be the other extremity of the loom that will plug in from side in the ECU and on the other end in the rev.
Thanx for your opinion on the illumination and ignition wiring if it ok.... Happy Travel
www.thegippo.wordpress.com
Post #285291 25th Nov 2013 11:00pm
sherifsalem
Has somebody done differently or confirm the same......i guess i confused everybody Big Cry Happy Travel
Post #285318 26th Nov 2013 9:19am
Martin
Site Admin
What you say is OK Smile
Taking power, illumination and ground from another nearby gauge is the way to do it.
You need to add a pin to 19 on the black ECU plug - it does look like this is empty on yours. This goes to the terminal "2" on the rev counter with Croytec's long grey wire.
The clock's wiring is:
BLACK: 0V for clock and illumination
RED/ORANGE: illumination 12V
PURPLE/BROWN: permanent (always live) 12V  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #285320 26th Nov 2013 9:54am
sherifsalem
Thanx Martin for your reply....
One more doubt Martin can you understand from this picture of the 3 wires, which is what?
appreciate it Happy Travel
Post #285370 26th Nov 2013 1:47pm
Martin
Site Admin
BLACK: ground
WHITE/GREEN: 12V switched with ignition
LIGHT GREEN/BLUE: coolant temperature signal (PWM on Td5)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #285372 26th Nov 2013 1:57pm
sherifsalem
Done sucessfully, just to close the thread...
 Happy Travel
Post #288176 6th Dec 2013 4:11pm
pjb
A rev counter always a good mod Thumbs Up 2020 P300 HSE
Post #288178 6th Dec 2013 4:24pm
sherifsalem
I actually stopped looking at the speedo Mr. Green
Fitting instructions for fellow enthusiasts, my account
http://thegippo.wordpress.com/ Happy Travel
Post #288184 6th Dec 2013 4:45pm
