![]() | Home > Technical > Puma Cuts Out – Why? |
Yes agree Lorryman
unit could go wrong be shorted out ,water ingress etc etc All I was saying if unit is working right ( as standard settings ) its only allowed to stop it starting not stop engine once running and if right fob/key used and fob is not checked once running correctly MY MATE SAYS WE SHOULD GO BACK TO HORSE AND CART , THINK HE IS RIGHT SOMETIMES Bloody cars !!!!!! |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Yet the workshop manual tells you the 10AS will not send a valid mobilisation code to the IPAC if the fob is not present and this will inhibit the starter and injector circuits stopping the engine
stopping it from starting? .. not stopping the engine once running
think its just the way its worded in the manual |
yes it can stop the engine if its got water in it or something wrong with it but that's not standard or working as it should.
I was saying about the theory of the unit checking the key fob every 5 mins or what ever that someone said about on forum and stopping the engine, it doesn't as I took my key fob off for 25 mins yes this for one that has no problems .. not got water in it etc I did not say if the as10 was knackered it would not stop the engine Out of interest how did it start in the first place if immobiser code could not be sent |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
Sorry if I missed something......
Not as simple as a blocked fuel filter? |
it's all to easy to get dragged in to thinking problems are in electronics.When sometimes you have to go back to basics
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Landscope Member Since: 23 Nov 2013 Location: Cumbernauld Posts: 8 ![]() ![]() |
hi all I am sure its electrical! the garage wants to replace the fuel pump but I think its the immobiliser as when I brought it home it cut out again after 8 miles and then when I parked it up it would not start like starter would engage then immediately disengage and then it would do nothing at all when you engage the starter. left it for 30 mins and it turned over no bother at all!!
What do you lot think? Lorryman100 I would like it if you could manage over on Sunday to work some magic and see if it can be fixed..... Thanks Brian |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17598 ![]() ![]() ![]() |
Check that the main and starter circuit relays under the offside front seat are really firmly in their sockets. Pulling the relay should pull the connector block off the mounting tab before the relay comes out of the socket.
The starting symptoms you describe are common and are often attributable to one or other (or both) of these relays not making good contact. It may be worth introducing a slight kink in the legs of the relay to make sure all 4 are tight. It takes minutes to do and just might solve the problem. |
auntie_prawn Member Since: 16 Sep 2017 Location: Wales Posts: 1 ![]() ![]() |
Sorry to revive this but I'm hoping for some help as I'm having a problem which i suspect is the immobiliser on the key fob.
The problem is me and landrover are in Congo so I can't just take it to a garage. It was previously going into limp mode mid-journey which felt quite dangerous. WE replaced the potentiometer and then the filters, including head unit. ThIs made it much better. It no longer really seems to drop out mid journey, but sometimes it starts and stays in limp mode when I try to pull off (more or less no revs) and sometimes it's OK. It's safer than cutting out mid journey but it's still not reliable. I don't feel like there's anything wrong with the engine when it does go faster than limp mode. I think the problem now might be the immobiliser on the key fob and I need not to know how to disable the immobiliser so I can see if that sorts it out. I had ideas that it might be as simple as turning it on and then taking the battery out of the fob and just not using the fob any more but it seems from a read of this thread that it isn't that simple. Can anyone advise? I am not good on cars, but have someone who is pretty good at the mechanical stuff - but I don't think he'll be great on the electrics unless it's quite straightforward. There isn't a landrover garage here so I can't go into one to get them to look it. So far I've had the car for a year and only managed to drive it under 200 miles because of this problem and the time it's taken us to look at it so far, so I'm really grateful for any suggestions you have. I do have the 4 digit reset code for the key but I haven't tried that yet as I'm not clear what will happen if I get it wrong! Thanks for any help and advice, Lorna |
If your Defender is a TDCi the immobiliser can be disabled very easily but only with a Nanocom or similar diagnostic tool. It is however extremely unlikely that a fault with the immobiliser would put the vehicle into limp mode, it is much more likely to prevent the vehicle from starting or, just possible, cause the engine to cut out and not restart.
Do you have a fault code reader? Since something is happening to cause the ECM to put the engine in limp mode whatever the event is must have been detected by the ECM, so there should be stored DTCs ("Diagnostic Trouble Codes"). |
MartnH Member Since: 30 Oct 2017 Location: Nsw Posts: 28 ![]() ![]() |
Hi blackwood,
I recently had a similar issue. Do you know if the nanacom evo can disable mobiliser on a my13 puma defender? Or even able to code a replacement 10as (earlier version of the black box 10as on puma defender) to the ECU? Thanks Martkn |
