Home > Technical > 2012 110 uxs 2.2 tdci - Indicators not working - now working
NormanD
England 2015 Defender 110 Puma 2.2 USW Santorini Black
Strange occurance, I was indicating to turn right, only the indicators did not flash, but staid on?
Found a place to pull over and park to investigate, indicated to turn left, same thing, without stopping the engine, checked the indicators right and left, no flashing but indicators on. cheked the Hazard Flash, exactly the same, no flashing?
Turned off the engine, on re-starting everything worked perfectly, and has continued to do so.
Anybody any bright ideas as to the cause? NormanD WE191
2015 110 XS Utility
2014 VW Caravelle 180 Executive
Post #169945 22nd Sep 2012 4:50pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Probably just the flasher relay stuck ... Guns and Landrovers .... anything else is irrelevant.
Post #170042 22nd Sep 2012 9:41pm
natyeo
United Kingdom 2014 Defender 90 Puma 2.2 HT Santorini Black
Mine have been silly in the past , I sometime get this after a rough green lane and nornally just remove the flasher unit tap it and pop it back in , but did it on a normal road and just stay on , still under warranty so will pop it back in , how did you sort yours? 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
2012 2.2 tdci 110 Utility
1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going
1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms
1971 Series 3 88, Perkins 4203,M8000,SATs,O/D,
Post #283898 20th Nov 2013 11:40pm
T1G UP
loose relay, give it a wiggle
Post #284041 21st Nov 2013 5:04pm
natyeo
Went to dealers replaced relay , now fine watch this spec 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
Post #284191 22nd Nov 2013 9:52am
