Home > Td5 > Headlight dip/main beam relay buzzing and no lights!
Domlandy1
Wales
Hi all,
First time poster on here, been on disco 3 page a while, always owned land rovers of some description!
Right we have not long brought a 130 cherry picker for work. We've had a few little problems with it but nothing serious!!
Today the lads were out working with it an they ran the battery down as you can stop the engine from the basket an that leaves the lights on an the fuel pump running. They jump started it off another truck but as he was driving it back as it got darker he noticed the lights not working.
He got it back to the workshop for me to look at, I took it straight round to my local LR sub dealer to see if it was something easy as they needed it tomor.
We tried a pink headlight main beam/ dip beam relay, the short light switch and the indicator switch with no luck!!
To sum up my long drawn out story( sorry) you can push the light switch all the way down and you leave the big stalk in dip beam and no lights except side lights come on but you can hear the pink relay under dash buzzing, you can push the big stalk down for main beam and the lights come on but there really dim. You can pull on the stalk as if your flashing someone and they work fine but the relay is still buzzing.
Your help will be grateful about this!!
Thank you Bow down
Post #283832 20th Nov 2013 8:58pm
Domlandy1
Wales
Anyone able to help me please?
Thumbs Up
Post #283853 20th Nov 2013 10:09pm
I'm guessing you're talking about a late '90's vehicle? I believe that the pink relay is part of the dim/dip system as the lights themselves are controlled directly by the switch rather than via relays. You're best bet is probably to isolate the dim/dip system completely (and throw it away as it's pointless anyway). Failing that, it's out with a multimeter, I'm afraid, to trace wiring and check for shorts. Darren
Post #283883 20th Nov 2013 11:03pm
Domlandy1
Wales
Hi there,
It's a 2006 130.
Mm sounds like iam goin to be having fun with it tomorrow then!!
Thanks for your reply Thumbs Up
Post #283888 20th Nov 2013 11:09pm
kipperthedog
Sorted?
Post #284579 23rd Nov 2013 6:01pm
Domlandy1
Wales
Hi there,
Well nope not really, went to It the following day and all is fine except now there is no flash on the indicator stalk. Mm so no idea. Job for Monday now. It's ment to be goin to Anglesey early tues morn for a couple of days so don't want it dieing on them.
Oh the joys of land rovers Very Happy
Thumbs Up
Post #284587 23rd Nov 2013 6:14pm
