Home > Td5 > plug and play ecu??
sandylands
plug and play ecu??
Hi all, as a previous thread states, i have been struggling big time with 2001 td5 fender with jerky sensitive throttle, new throttle-maf-filters-all switches checked-clutch switch, hi low switch etc, so i think ecu- i do research that says a new ecu needs reprogramming- i have a hawkeye so not sure if i can do it with this but anyway the question is this- the current msb ecu was sent to me by the previous owner fom a company on ebay saying the ecus he supplies are plug and play!! and to be fair i took it out the packet-plugged it in and away it went (new ecu was required as owner wanted his mapped one back) Is it possible that this ecu is running on a basic system and needs proper programming to run my engine? How is it possible to have plug and play ecus??? I know ive asked before but has anyone gone to a nnn ecu and found the throttle less jerky. and if i buy a nnn ecu can i map it to my landy with a hawkeye?
many thanks
Post #283365 18th Nov 2013 10:12pm
roel
I know you can get ecu's that don't look for the Alarm ecu (a10?) but you always have to programm the injectors a.f.a.i.k. Roel
2003 90 Td5 (2009-now)
Post #283394 19th Nov 2013 12:21am
defninety
1985 Defender 90 Td5 XS CSW Bonatti Grey
Yes, plenty of people can now supply these ECU's with the immo bypassed, so do not require the ECU to be 'Synced' to your vehicle. I personally don't think it is a good idea to have one fitted to your own vehicle.
Unless someone supplied this company with all the injector codes for your vehicle or you have programmed them yourself, then it will probably be running the wrong codes and may even be on the wrong engine calibration for your vehicle.
I would start by checking these things first. I believe Hawkeye has the functionality to do this.
Post #283443 19th Nov 2013 9:54am
I've just taken the original discovery spec MSB ecu off of my 90 (and fitted a proper NNN flashable type, with the proper defender software)
My jerky throttle has gone and it's like a proper defender again.... all smooth and nice. It was really jerky before.
Post #283446 19th Nov 2013 10:05am
sandylands
Thanks guys, i found the guy on ebay that supplies the ecus and he says he programs a neutral set of injector codes-whatever that means and that the correct codes will make little difference, diesel jim that sounds like something i may well try, where did you get your ecu from may i ask?? it appears that hawkeye can code the injectors as long as i remove the rocker cover to get them. A bypassed immo doesn't sound great but i can live without it. My defender does seem to run smooth enough all bar the jerkyness in 1st but surely the correct codes will make things better?
Post #283499 19th Nov 2013 5:12pm
Got mine from Ben @ venom4x4.co.uk
he's just outside Reading.
Post #283521 19th Nov 2013 6:43pm
sandylands
Just to inform anyone who may have also bought or is thinking of buying a plug play ECU, the nutrual injector codes work just as well as the proper codes. more wasted time lol. Diesel Jim do you notice any difference in your anti stall with the nnn ecu. I honestly think a nnn ECU is the only way to improve my situation
Post #284989 25th Nov 2013 12:01am
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
There is no reason why the proper MSB ECU wouldn't work with your 10p engine (assuming that's what you still have fitted?)
The NNN is flashable which makes remaps easier but if proper running isn't what your trying to achieve then the NNN isn't the fix. www.td5.org
Post #284991 25th Nov 2013 12:59am
Just to add, the MSB ECU that my 90 was running, was a discovery spec one, hence why the throttle was so jerky (and temp guage was back to front)
@ sandylands.... to be honest, not noticed much difference in the antistall. although i've not really tried it in anger yet. the idle is much smoother though (running the defender software as opposed to the disco)
Post #285006 25th Nov 2013 7:34am
