Draining and filling the radiator
Evening all.
Thought I'd get round to one of those Sunday afternoon jobs and change the coolant on my Td5 since I've clocked 100,000 miles and the radiator hasn't been touched for the last 50,000 anyway.
Took the bottom hose off to drain it. Flushed the system by tipping 10 or so litres down the expansion tank.
I then refilled the tank with coolant untill it bubbled out the bleed screw in the top hose.
The problem is I only used 3 litres. The LR book says 13 litres.
Took it for a short drive to get it up to temperature but no change in level.
Any suggestions? How do I add the other 10 litres of new coolant?
Many thanks in advance
Paul2003 Td5 90XS
1970 Series 11A 2.25TD
2013 Freelander 2 HSE Lux (the wife's)
17th Nov 2013 10:49pm
dorstsmith2
Air lock in the system, it is problem. The only way i have fond to shift the air lock out is to, flatten coolant pipe work to shift the air lock and keep topping long job i no
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
