Home > Technical > Rear demister issue - TDI
Riksbar
United Kingdom 1997 Defender 110 300 Tdi CSW Alpine White
Have a 97 300 TDI CSW and amazingly the rear window demister actually works. The down side is it won't stop working. When the switch is off it will randomly come on, lighting up the annunciator lamp even when the ignition key is out. This has drained the battery several times. I have disconnected the heater array, removed the fuse which seemed to have burned and the light is still coming on. Any ideas?
Post #283046 17th Nov 2013 8:59pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
Get a multimeter on the thing!
Check at the fuse box if power is at the fuse when it is off. I don't believe they are meant to have power permanently - only switch power (ignition switched).
My initial thoughts are some sort of wire chafing or similar.
Need to get the meter out and follow the power back really.
Post #283504 19th Nov 2013 5:42pm
