Home > In Car Electronics > Factory Radio Removal |
kharnsflair Member Since: 17 Sep 2013 Location: South Posts: 12 |
I took the dashboard out around it on a TD5 (bless Defenders). Hopefully a newer one isn't much harder.
15th Nov 2013 3:25pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20583 |
Yes, I'll PM you the details or I could pop it out for you? KEEP CALM AND Drill ON
๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
15th Nov 2013 3:28pm |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
I would like to try in the next 30 mins Steve if you could PM me 2008 TDCi 2.4 XS CSW
15th Nov 2013 3:29pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2767 |
if it helps you, halfords will (if you ask correctly) let you use their keys (make them think you want to see the connections on the rear to help you buy something from them)
or you can buy them for like ฃ3-5, they're usually open til 8 or later Cheers, David Land Rovers of all shapes S3 onwardsโฆ Daily is a 110 V8. |
15th Nov 2013 3:33pm |
PM'd KEEP CALM AND Drill ON
15th Nov 2013 3:39pm |
Well I couldn't get to Halfords today as Chipnum was closed due to a big accident, so i made 2 x removal tools from a wire coat hanger....Pioneer fitted and firmware updated
JD 2008 TDCi 2.4 XS CSW |
16th Nov 2013 7:46pm |
16th Nov 2013 8:01pm |
alsalloumabdul Member Since: 25 Nov 2013 Location: Kuwait City Posts: 3 |
Nope, you need two proper steel/plastic sticks. |
25th Nov 2013 9:05am |
Where there's a will there's a way! Johnny hope you're still happy with the truck! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
25th Nov 2013 9:20am |
You can remove the whole centre panel (the bit with all the switches and clock on)
Just need the right torx head and then use a large flathead screwdriver to pry it forwards at the edges, not too hard. You can then push in the bits that hold the radio into the cage manually Cheers, David Land Rovers of all shapes S3 onwardsโฆ Daily is a 110 V8. |
25th Nov 2013 10:03am |
