Home > In Car Electronics > Halfords Speaker Range
johnnyd
Can anyone recommend a pair of speakers from Halfords as a direct better replacement for the front speakers in the 2.4 XS (not sure how different other models are)
Or are all Halfords speakers rubbish ?
JD 2008 TDCi 2.4 XS CSW
Post #282650 16th Nov 2013 12:03pm
Over priced and limited selection, 10cm is the size you want. (For easy installation anyway)
Have a look at these http://www.ebay.co.uk/itm/KENWOOD-KFC-S109...5d3c4b08c6
Or these
http://www.justkenwood.co.uk/car-audio.aspx/kfc-e1065-speakers
I have the more expensive ones but the later model, there are Pioneer iirc that are a tad more powerful for the size but depending on HU you've chosen you really want the same brands on most things if you can. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #282652 16th Nov 2013 12:25pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
I went to a locally recognised audio specialist who recommended Kenwood to me for HU and speakers and an Alpine active sub.
I listen to most genre of music and I am very please with the quality and general output.
I had 2 speakers blow [after a slight shorting issue Whistle] and replaced them with the speakers recommended by Customsteve in the ICE thread - thanks
Regards BM52
Post #282675 16th Nov 2013 2:59pm
"Slight shorting issue" Shocked Surprised Shocked what did you do? Rolling with laughter WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #282679 16th Nov 2013 3:08pm
bm52
Let's just say I was listening to some nice music and some twit decided to re-route a couple of wires with a coat hanger up the back of the bukhead and ......... Shocked no more music at the front, blown fuse and crackly speaker afterwards. Banging Head so I needed to buy 2 new ones.
I've undertaken a lot of wiring on vehicles and I think that was the first time a fuse was blown - live and learn. BM52
Post #282747 16th Nov 2013 7:35pm
johnnyd
Is that live and learn or 'LIVE and learn'
Rolling with laughter Rolling with laughter Rolling with laughter
Post #282756 16th Nov 2013 8:02pm
Always best to remove the fuse, trouble is a lot of us are guilty on that one! And to lazy to disconnect the battery even. Rolling with laughter
On the bright side at least you didn't short and Amp cable! Otherwise you'd very quickly end up doing a bit of welding! Surprised WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #282766 16th Nov 2013 8:22pm
johnnyd
Hi Steve
Which of those two links would you say were the best speakers ?
Also are you sure i want 10cm, the outer grill of mine measure 13cm?
JD
Or these
Post #282907 17th Nov 2013 5:26pm
Yes, 10cm the size is measured on them by the mounting hole diameter not the speaker outer diameter. Thumbs Up
If you want more bass as standard I would say these: http://www.justkenwood.co.uk/car-audio.aspx/kfc-e1065-speakers
They go down to a lower frequency to the ones I have hence a bit more bass, mine are slightly higher frequency but I have the Sub to make up for it. The ones above should be a good all rounder.
Funny enough Kenwood seem to have reduced their range a little for the 10cm speaker range, unless it's just stock availability on Just Kenwood. They give you free delivery and 1year warranty. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #282909 17th Nov 2013 5:36pm
johnnyd
Hey Steve, do you know max depth available ? Looking at these
http://www.inphaseaudio.co.uk/products/spe...ge/xt42ii/
30 quid from tesco
Post #282947 17th Nov 2013 6:55pm
barbel jim
In Phase Rolling Eyes Rolling Eyes Rolling Eyes Don't bother Whistle But yes they will fit I put some in a puma for someone. He liked them but I'd sooner have half a tank of diesel Whistle
Post #282953 17th Nov 2013 7:02pm
johnnyd
Oh Embarassed
What have you got Jim?
Post #282955 17th Nov 2013 7:04pm
It's a bit tight for a 13cm (a lot more modification to fit anyway) but a 10cm for depth should be okay what ever depth they are. It's the OS that is the tighter area.
Cannot give you any guarantees though I'm afraid but should be okay.
Closest runner for me personally I'd choose bar what I currently have is these:
http://www.halfords.com/webapp/wcs/stores/...yId_265869
Love the looks of them too, drool* Laughing
What ever you get keep the recipt and just place it in position in the hole if it's fine both sides your good to go. If not just take back for a swap or refund.
Thumbs Up
I would stick to premium brands though. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #282959 17th Nov 2013 7:09pm
Johnny - Jim and I are arch rivals when I tomes to brands. Rolling with laughter But we do get along all the same though, just. Twisted Evil Laughing WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #282961 17th Nov 2013 7:11pm
barbel jim
5" Focal polly glass but I did do some butchering for them to fit Whistle Not much help if you just want plug and play. CHRISD90 has just fitted these http://www.focal.com/en/universal/389-isn-100.html See his thread http://www.defender2.net/forum/topic24606.html.
Post #282965 17th Nov 2013 7:14pm
