![]() | Home > In Car Electronics > Parrot CK3000 Evolution Bluetooth kit |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20645 ![]() ![]() |
What HU / Radio do you have installed at the moment? TheThunder Rollsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
9t Member Since: 09 Nov 2013 Location: Johannesburg Posts: 108 ![]() ![]() ![]() |
It's the standard unit that came with the car - an Alpine CD Receiver - model number CDE130R. '13 Defender 90
'10 Freelander '13 BMW R1200GS '62 Triang Tricycle Previously '04 R1150RT; '11 F650GS; '98 Defender 110; '03 Defender 90; '02 Freelander |
IIRC the Parrot kits connect "in-line" of the wiring harness, which is normally ISO connectors on the Parrot. Not an issue in the 2.4 Defender as it is ISO as standard.
Not exactly sure how they have configured them now, but if the HU accepts an ISO connection and the 2.2 is specific all you should need is an ISO adaptor. Problem would be is if the HU isn't ISO, then you would need to change it. Not likely IMO but a possibility. Another owner can likely clarify that quickly for you. TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Thanks Steve, installation has just been completed and it works like a charm. Thanks for the advice. '13 Defender 90
Your welcome, glad it's going well.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
