Home > Td5 > Do you need to change the clutch after tuning?
Page 2 of 2 <12
JWL
I've found that clutch slip at higher revs, that point when you're just about to change gear, can often be down to contamination of the friction plate. I had those symptoms when my fuel pressure regulator was leaking, again when there was an oil leak on the rocker cover via the semi circle bit of gasket. It was really noticable in wet weather and there's a junction I sometimes pull out of where it is necessary to boot it to get into the traffic flow. I could stall the thing at tickover, no problems towing but when upping the revs towards the higher end it would slip. Those symptoms have all gone now that the leaks have been sorted, mines on 160k and still on the original clutch. I've known some people spray a tin of brake cleaner in the bell housing to degrease the plates.
Post #281763 12th Nov 2013 10:37pm
roel
I don't think it is a grease clutch but I will check. I replaced the fuel regulater about a year ago and I didn't see any oil coming out the bell housing.
The clutch slips as soon as the turbo comes is or if I give some throttle in the middle rev range. I higher revs (3500+) it doesn't slip.
Here a video off last Sunday:
http://www.youtube.com/watch?v=i9bSD248YLo Roel
2003 90 Td5 (2009-now)
Post #281783 13th Nov 2013 7:14am
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
total carnage...........pay n play sites. Those girls in the Jimny were lucky... Putting Dreams on Drives at JLR Solihull..
Post #281801 13th Nov 2013 8:39am
K9F
Would you go offroading with the tyre tread on the Jimmy? They looked shot! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #281802 13th Nov 2013 8:58am
roel
At least for them the hills were interresting. With the Simex tyres I could just walk up most off the hills except the one I needed severall attempts. I succeeded but that time my codriver didn't have the camera on. Mr. Green Roel
Post #281809 13th Nov 2013 9:27am
K9F
It looked a very busy site. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #281810 13th Nov 2013 9:30am
roel
Yes it is a once a year event after the motorcross season.
125 cars max. I was there half an hour before opening and I had number 76. So I think there were more then 100 cars. But it is fun seeing the lesser cars struggle while I just drive around looking for more difficult spots. Roel
Post #281825 13th Nov 2013 10:28am
K9F
The multi-coloured Defender seemed to cope very well. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #281831 13th Nov 2013 10:49am
roel
Yes thanks,
But it's a 90 td5
with 35" simex tyres
and a Detroit locker in the rear diff anda truetrac in the front so what would you expect. Twisted Evil Roel
Post #281992 13th Nov 2013 9:29pm
Page 2 of 2 <12
