![]() | Home > Puma (Tdci) > Anyone fitted a dual mass flywheel to tdci |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
Yes as said I will be changing it to a solid as and when I have problems
![]() My truck has only done 4k though but it is pulling 35s round 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
JoostKenya Member Since: 31 Jan 2010 Location: Naivasha Posts: 9 ![]() ![]() |
You are thinking "static" and not "dynamic"! Please read something like this: http://www.schaeffler.com/remotemedien/med...heel_1.pdf What I tried to say: the Defender has different spring and mass (=inertia) properties in the drive train and therefore different natural frequencies. So most likely you are not going to bennefit anything from fitting a DMF of a Transit in a Defender because it is not optimised for this vehicle. But it will work and maybe you are not going to feel any negative compared to a solid flywheel. Joost Defender 110 Puma 2.4 Tornado TD5 Racer Defender 110 V8 Defender 136'' 300Tdi Safaricar SIIA V8 Hybrid |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3664 ![]() ![]() ![]() |
This is interesting, I wondered if a rubber coupling as per disco 1 in one of the drive shafts would smooth everything out a bit DEFENDER 90 TDCI XS,
So the DMF is optimised for transit engine ... They do 4x hp ratings .. Lots of load carrying rates about 100 different body's .. We get from the swb 90 hp van to ambulance weighting 4.3 ton all running the DMF |
I would be very tempted to fit DMF when it comes to fitting clutch as I can't see it doing any harm .. If there fitted to some vehicles to take engine vibrations out . May help with transmission rattle etc ... Only fitting one would tell?.
After 20 years of racing and few championships , winning hundreds of races , his own fan club under my late fathers belt .. Building our cars , building our own engines. Playing with ratios etc etc it's in my blood to try different things .. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17718 ![]() ![]() ![]() |
Hmm, I wonder why LR went to the trouble and cost of developing a solid flywheel for the Puma when there was a DMF option available off the shelf.
Maybe there was a solid flywheel already if it's the same as transit conversion .. But it's not much to make a flywheel if you know the weight and dimensions . And Worth doing if your going to use thousands of them . We used to make our own ..
I heard it was because of DMF problems in transits Or was it cost .. Solid is a lot cheaper to make .. Solid= one piece . There must be 20 bits to DMF Look at the cost cutting they have done bad chassis paint etc even the rear door lock support gone! But I would like to know if loosing the DMF causes gearbox problems seems a lot of problems listed on this forum Solid conversion for transit was supposed to by bad for the same transit box as the defender All the testing by land rover (if any) between solid and DMF can not account for wear and tear of thousands of different drivers Doing thousands of miles some towing some off roading some driving like ----- Tdci puma gearbox £3000 I read on here somewhere .. DMF £300 . Ok they don't last for ever but say you get 40,000-50,000 out of DMF (but have seen careful drivers get 100,000 out of them ) 150,000 miles = 3xDMF + maybe couple of starters =£1200 THAT'S ALOT LESS THAN A GEARBOX WOULD FITTING DMF BE BETTER ? DON'T KNOW But I would like to find out wouldn't you |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20749 ![]() ![]() |
Would my 90 be a solid or DMF Flywheel?
What is the difference? |
solid is one piece
dual mass has a built in damper , the bit the clutch grips on can move round a bit , really just cushions the drive I was told the other day that the very first pumas had dmf then changed to solid we were always told the solid conversion for the transits which is a lot cheaper then clutch kit + dmf was not so good for the gearbox as fitting a proper dmf set up |
Steve, all Pumas have solid flywheels (and sprung driven plates).
Thanks Blackwolf, I'm assuming then some transits are DMF and not defenders.
Munch90 I'm with you on this, if there is one that fits straight in I think its worth a try just to smooth everything out a bit and get rid of the useless clutch plate DEFENDER 90 TDCI XS,
i was told the first ones had dmf by a big well known indepentant land rover garage whos knowledge I have often tested ringing up about problems with many customers cars and found them very knowledgeable , also there was one listed on ebay with a lr part number that was dual mass
but was told also now the part number goes over to solid flywheel as lr no longer supply a dual mass |
if mine ever comes up to needing a clutch , I would like to go the root of luk dmf and luk clutch as I would not want to fit a ap clutch anyway we never seem to get a problem with luk stuff and have fitted hundreds of them to all makes and models and please don't tell me just because ap is oe fitted its better |
