Home > Technical > Starting intermitent powr failure
2buckland
United Kingdom 2008 Defender 90 Puma 2.4 ST Auto Barolo Black
Hi there,
I have a bit of a wierd issue with my Defender. Sometime when i go to start the car, just as i go to turn it over, there is a click and all power is lost. I have no alarm radio or any power at all. If i leave it for a few minutes it will start normally.
I also have an issue when i turn it on i get all power but it won't start.
The vehicle has been rebuilt recently so there could be a wire in the wrong place but it seems odd this is intermitent. If anyone has an idea what his might be it would be much appreciated.
Many thanks,
Cris
Post #280923 10th Nov 2013 10:29am
jimbob7
Check and clean the starter motor connections.Also I think the starter relay is in the lower dashboard fuse box,let us know how you get on,oh and welcome to the forum. Pov.spec,ftw. 2006, 110,TD5.
Post #280934 10th Nov 2013 10:53am
Laurie
Check your battery, earth and starter motor connections.
Post #280937 10th Nov 2013 11:08am
JWL
I'd go as far as to say starter motor solonoid. You can probably get refurb kits much like the Td5 ones for less than a tenner. Sometimes taking them apart and cleaning the contacts will do the job.
Post #280938 10th Nov 2013 11:14am
2buckland
Thanks for the tips, the thing is the power comes back after leaving it. Therefore if the conection was faulty it would stay off. I am wondering if this is an immobiliser issue but i am not sure if the immobiliser works by killing all power or just the ignition or both.
Just to clarify, if you put the ignition to the first click or off there is no power, the alarm does not work and niether do the lights or radio. Sometimes i have all power but no start.
Post #280941 10th Nov 2013 11:36am
Laurie
Is it a loud click as from the solenoid or a gentle relay click from behind the dash?
Post #280943 10th Nov 2013 11:40am
2buckland
More a relay click from behind the dash.
Big Cry
Post #280983 10th Nov 2013 4:25pm
How old is the battery also? Might need checking / replacing. TheThunder Rolls🇬🇧🇺🇸
Post #280991 10th Nov 2013 4:59pm
Cheshire110
Check your earth (and +ve while you're at it) on your battery, can cause some weird symptoms. A bad connection will not allow enough current to be drawn, so make sure both clamps are 100% tight. Cheers, David
Post #281015 10th Nov 2013 6:16pm
2buckland
Thanks David, it was loose. Hopefully that was the issue. Feel a fool for not checking that myself! Embarassed
Post #281046 10th Nov 2013 7:57pm
Cheshire110
No worries, fingers crossed it was the problem!
Drove me crazy having similar issues after I had fitted my amp and extra speakers which involved disconnecting the battery. Would make a loud click and lose all power when I tried to start the engine.
Now we know! Cheers, David
Post #281052 10th Nov 2013 8:04pm
I had it too once, you can find find too that it'll start fine when you leave home but as you travel to your destination a few bumps can make the connection worse. So when you park up and then come back to go home you'll get the symptoms you described.
Some petroleum jelly on the terminals can give an even better secure connection. IMO the earth connection on the battery is the worse one for being loose, it has a not very efficient clamping bolt. TheThunder Rolls🇬🇧🇺🇸
Post #281058 10th Nov 2013 8:10pm
