Home > Puma (Tdci) > Difflock drain plug and hose |
jlerra Member Since: 10 Jul 2009 Location: Gibraltar/London Posts: 149 |
Hi all,
I have just placed an order for the Difflock Drain Plug and Hose for thr Defender TDCi Puma. I have waited a long time for this and they are now available. This makes the oil change a singe with no mess whatsever, see Difflock website for picture. Should anyone be interested in obtaining this you can contact Justin at sales @Difflock as he hasn't yet got the catalogue number sorted yet. Great piece of kit making oil changes from the sump almost a pleasure even without lifting the vehicle. Thought I might inform all of this. Cheers Joe 'El pepe flamenco' JLS 'El Pepe Flamenco' |
24th Mar 2010 2:55pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
Similar story - had one for probably about 5+yrs - great things.
When i take up my own service i will get a puma one...untill then there is little point. Mike |
25th Mar 2010 1:41pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Do they stick out the bottom of the sump? I assume they're not that exposed. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
25th Mar 2010 2:36pm |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 |
They stick out only slightly more than a normal plug, but that is because of the removable cap to keep the plug clean. Definately not exposed though |
25th Mar 2010 7:25pm |
Ive never had or heard of a problem off roading with them - they also do them for other makes not just LR's Mike
26th Mar 2010 7:23am |
Right then. Added to the list when I'm out of warranty (which is rapidly approaching ) One that started out as a 2.4 TDCi 110 XS
26th Mar 2010 9:23am |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
I've been waiting for this, especially as the Puma sump plug has the rubber gasket as part of it and therefore is a replacement item every oil change. Never bothered with the Td5 or Tdi ones as the replacement washer d.idn't cost much, but now I'll consider it 110 2.4TDCi
110 300Tdi LROCV ::: AULRO.com |
26th Mar 2010 8:09pm |
