Home > In Car Electronics > Electric windows to work with key in position '1' not '2' |
Bushpig Member Since: 07 Nov 2013 Location: Risca, Wales Posts: 236 |
Hi All
Firstly, this awesome forum has been excellent help with my new Landy... To change the operation of the electric windows from position '2' to '1' on the ignition (2012 2.2 puma)... Is this something that can be done via the cpu or is it a rewiring job? For me there is nothing worse than being in the bush and having to turn the key to '2' so the windows will work (the fuel pump turns on and completely disturbs the ambiance...) Thanks for any help in advance. |
7th Nov 2013 11:39am |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2658 |
Theres 2. 1 under the driver seat and the other is under the steering wheel, where the OBD port is 110 D250 SE HT
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
7th Nov 2013 6:56pm |
Thanks diesel_jim
I'll have to get some courage before I go playing with the wiring. Thanks again |
8th Nov 2013 1:59pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17382 |
The window lift relay R143 (under the column) is connected to 10A link 3 in the BJB (under the driver's seat) whcih is permanent live. The relay is energised by a switched supply from the ignition switch, which passes via 5A CJB Fuse 15 then header K109 to the realy. When the ignition is switched, the relay is energised, and the windows can operate.
Header K109 (on the bulkhead under the column) is way too complex to mess with (it distributes the ignition feed to the headlamp relay, HRS, HFS timer, IPAC, dim-dip relay as well as the window lift, and also joins two of the main harness segments together with many other connections), so I would suggest that any mods you want to make should be "downstream" of this header. If you could take a feed from 5A CJB Fuse 44 (radio) and connect it to C0042-85 (the "85" connector on relay R143) you shoudl achieve the desired result. Make sure you insulate and secure the cut end of the original wire to the relay since it will still be live and conncted to many other circuits, |
8th Nov 2013 2:47pm |
blackwolf, a big thanks, but I'll be definitely be purchasing a case of beer and inviting an auto electrician mate around for this one...
10th Nov 2013 7:21am |
Thought I'd revive this this thread...
My list is running short so this mod has returned to the top 5... Anyone else out there done this? Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. Douglas Adams 2012 2.2 Puma |
14th Jun 2017 1:03pm |
