Home > In Car Electronics > FAO: BP Man, RE: iPad Mount |
hi Interlet
I used a ram mount on the grab rail, I also fitted a ram mount to the cubby I always buy direct from ram mount.co.uk, they have the best prices I have a toughbook and an ipad, both work with a 1 1/2 inch ball ipad mount: http://www.ram-mount.co.uk/device-mounts-a...0_673.html grab rail mount: http://www.ram-mount.co.uk/clamp-base-with...8_287.html universal mounts: http://www.ram-mount.co.uk/fishing-rod-mounts-c-490.html#p23 there is a pdf downloadable catalogue: http://www.ram-mount.co.uk/applications-z-17.html I tend to buy a bunch of bits, then send back the items I don't need, the guys are very helpful. |
7th Nov 2013 7:39am |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
Interlet, if you're talking about fitting the RAM mount to a TD5 or TDi dash, I will post some pictures later.
The lower dash rail isn't strong enough to take the weight of mount+iPad, so I made a simple Ali plate that fastens between the upper and lower dash rails. It's as solid as a rock and very simple. Cheers Simon Edit: Pictures added Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
7th Nov 2013 8:20am |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 |
Cheers guys very helpful.
Looking at the ram uk site, would a 1.5 inch ball be suffice to hold an iPad stable or should I go bigger. 1998 110 300Tdi White Hard Top |
7th Nov 2013 10:20am |
1.5" is fine for ipad, toughbook etc.
7th Nov 2013 11:46am |
Just looked back at my order from RAM and this is what I got:-
1 ea. Mount with Standard Arm and 2.5" Round Bases £46.93 1 ea. Tab-Tite™ Universal Holder for 10" Tablets with Heavy Duty Cases £29.80 The mount has 1.5" balls ( ) and the whole thing is solid as a rock. http://www.ram-mount.co.uk/mount-with-stan...p-987.html cheers simon |
7th Nov 2013 12:04pm |
