![]() | Home > Puma (Tdci) > 110 rear springs specifications |
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 ![]() ![]() |
Anybody ever find the specs for the RKB500300 Green/Green/White springs??
Cheers, Tim |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4742 ![]() ![]() |
The only thing I can find is
NRC 8045 Passengers Double yellow stripes 110 Front Basic NRC 7000 Passengers levelled Green and white stripes 110 rear suspension levelled Probably not much help 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166 ![]() ![]() ![]() |
The front spring I use on my 110 is NRC9448/9 which is standard 130 fronts, works well with ARB bar and winch, the only listing I have for genuine hd Land Rover 110 rear spring is NRC6904/6989. RKB101111 is vin XZ159807 up.
Allan Last edited by Allan on 12th Jul 2010 2:13pm. Edited 1 time in total |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2453 ![]() ![]() ![]() |
There is no data for those springs, but I would say are eq to the 270-420 lb/in. I have OME 755 and beside they are 1 inch longer, feels the same. Puma 110" SW
stevieb Member Since: 19 Nov 2010 Location: Warwickshire Posts: 2 ![]() |
Hello Chaps,
This is an old post but if people still want to know specs of RKB500300 white/green/green: Its a triple rate spring. 1st 47.2N/mm, 2nd 55.3N/mm, 3rd 71.2 N/mm. Mutliply by 5.7099 to convert to lb/in. Hope this helps! |
ugo Member Since: 19 Mar 2010 Location: Milan Posts: 6 ![]() ![]() ![]() |
What is your source? J'aime l'Afrique
Hello Ugo
I've got the drawing in front of me right now. I was requested by our marketing department today to provide the info for a customer, that customer's name was Ugo....... Posted up here as I saw a few people were interested. Hope it's helped! |
Mymistake.
makes a lot of sense. But triple
![]() ............................................................. Earth first. Other planets later |
is the departement land rover military ? J'aime l'Afrique |
szracer Member Since: 10 Oct 2010 Location: Cotswolds Posts: 356 ![]() ![]() ![]() |
OK, as someone who's looking for softer rear springs to replace the (HD?) brown/purple springs on my 110 USW, with something a tad softer, I'm confused....
![]() Looked up RKB500300 with several online parts vendors and they list it as being brown/purple! ![]() 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
mega Member Since: 23 Oct 2010 Location: notts Posts: 33 ![]() ![]() ![]() |
szracer.I have replaced the std h/d springs on my USW with the white/green/green from the SW, tri rate.269lbs -315lbs-406lbs. Much improved ride
today i have received the answer by Land Rover. thanks stevieb
i bought some -2" springs from extreme4x4 for my puma, they must know the specifications of std puma springs.
