Home > Technical > Spot light original connectors
airpusher
Wales 2006 Defender 110 Td5 XS DCPU Zambezi Silver
Ok seeing as I'm stuck on the Eurostar waiting to go through the tunnel. I may as well see if someone can help.
I've had a search and found some bit of info but nothing on the actual connectors.
I have the wiring loom already fitted to my defender for spots, I want add some and use this loom. I've looked at the connectors on the end, but can't find the matching plugs to add the spots.
I know I can get econosesl plugs but if possible would like to use what's there without chopping.
Does anybody have any idea what the part number may be or even if they are obtainable?
Cheers 2006 Defender Double Cab- Zambezi Silver
Post #279457 4th Nov 2013 6:56pm
bob neville
Here you are Thumbs Up
http://www.polevolt.co.uk/acatalog/Econoseal_Connectors.html
These fit the original LR spot loom - I have just fitted them to four spots that are connected to original looms Thumbs Up
2013 Defender 90 CSW - sold
Post #279472 4th Nov 2013 7:20pm
airpusher
Excellent, thanks Bob.
I was looking at that site but really couldn't figure out if they would fit.
Oh and I love the colour of your new 90. So tempting if I could. 2006 Defender Double Cab- Zambezi Silver
Post #279478 4th Nov 2013 7:25pm
bob neville
Cheers Thumbs Up
ESC2M - 2 way Econoseal male connector with terms and seals.
Plus, you may need 3-4787-2/10 Econoseal wire seal 1.5mm - yellow.
I needed the larger seals to fit on the Lightforce spots so may be worth getting as well.
I set of Econoseal crimps makes fitting them a breeze.
Post #279486 4th Nov 2013 7:42pm
leeds
If you just need a couple send me your address via pm and I can stick a couple in a jiffy bag to you.
Brendan
Post #279506 4th Nov 2013 8:18pm
airpusher
Bob, that great mate. Thanks.
Brendan, that's very kind of you mate. I'll PM my details later, it's just for 2 spots.
Thanks 2006 Defender Double Cab- Zambezi Silver
Post #279615 5th Nov 2013 5:01am
