Home > Maintenance & Modifications > Done to death, but .... suspension
RickH
I have a 2002 TD5 90, which has started to exhibit a little lean on the passenger rear corner. Nothing looks bust from underneath, and my gut feeling is the shock has given up the ghost.
This leads me to three options, depending on needs and budget;
1. Replacement single OEM shock: cheapest, quickest but leaves the characteristics the same.
2. Upgrade replacement shocks (and springs): consistent upgrade across the corners, more expensive, slowest but can build a handling upgrade in.
3. Upgrade plus lift: not convinced I need this as I'm mostly one-road (bar the unsurfaced track to home at about 400m long).
I'm erring to option 2, but don't know where to start. Standard height, upgrade strength. But do I go springs and shocks, or just shocks? And who to go to?
Post #279024 3rd Nov 2013 9:04am
ibexman
Replacing shocks will not rectify your lean
Post #279025 3rd Nov 2013 9:12am
RickH
So it could be a mount, or the spring?
Post #279026 3rd Nov 2013 9:13am
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
Its more likely to be spring sag, this is when he spring gets worn out and naturally drops, the cure for which is to replace the springs. Shocks don't help to 'hold the vehicle up' as it were, just dampen the jolts from driving.
If you've been happy with the height until now then there is no point in lifting it.
Replace with OEM springs and new shocks. Your choice of shocks will be driven by budget and what you hope to achieve, search the forum for a range of opinions. Old Man Emu and Koni generally get the best reviews but depends what your after: if you've been generally happy with the ride until now replace with standard LR items and you'll still probably notice a big improvement.
Take a bit of time to think about what springs you need, if the ride has been harsh to this point you can get something a bit softer, if it has been too soft then can get something a bit tougher, this spring guide can help to decide which LR items to get: Spring Guide
You can undertake all the work yourself with a couple of decent jacks, axles stands, a set of spring compressors (actually you can do it without these if you can get enough axle articulation) and general hand tools.
Also, dinitrol / waxoyl inside the mounts when you have the spring out.
Post #279031 3rd Nov 2013 9:32am
Mdm
Keep it standard
Buy cheap buy twice
Post #279208 3rd Nov 2013 9:03pm
RickH
What exactly do you mean? I'm not going for the cheapest option. I want a cost effective solution given my expected usage. I've seen suspension packages measured in Łk's which are probably great. But I'm not going to test them. So I need sensible suggestions as to up the resilience of a standard height d90 that won't break the bank.
Post #279231 3rd Nov 2013 9:55pm
Mdm
Option two based on what you have posted.
I have tried quite a few brands over the years ome and Lowell's lasted the longest .currently using d 44 set up which suits me and is good off road combined with Gwynn lewis gear .
Without calling some brands cheap springs will sag within 12 months depending on use.
If you can its best to buy a matching kit suited to your needs.ring Gwynn or d44 for free advise. No doubt some other posted will suggest recommend more firms but these to have always given me good advise and service.
Post #279236 3rd Nov 2013 10:05pm
jst
how many miles has it got and whats its history?
check for bent/corroded mountings first.
assuming all good and reasonable mileage, high usage then look to change two rear springs only, stick with Std if the vehicle has always handled and done what you wanted. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #279242 3rd Nov 2013 10:21pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Standard springs for me too plus Koni shocks, if you do buy non standard don't forget to check your inurance as any changes could be considered a mod which could void your insurance if not declared BM52
Post #279245 3rd Nov 2013 10:40pm
Greg L
Scotland 2000 Defender 90 Td5 SW Epsom Green
PM sent RichH
Post #279257 3rd Nov 2013 11:31pm
Without sounding like an anal tw@t....
the springs are actually the "shock absorbers", as they take up the shocks from the road.
the bits that look like hydraulic rams are the "dampers", as they dampen the cyclic effect from the springs (without them you'd be wobbling up and down like a jelly!)
Post #279276 4th Nov 2013 7:43am
Re: Done to death, but .... suspension
I'm not quite sure what you mean by this, but I'm sure that you know that you should never replace one 'shock absorber' (i.e, damper) on its own, always replace an axle pair.
Post #279289 4th Nov 2013 9:03am
RickH
I know. But I like to state 'options' even though they're not strictly viable. Anyway, I'm yet to see springs sold as singles so it's a moot point. Maybe for clarity I should say replace the rear springs.
Post #279346 4th Nov 2013 1:12pm
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Not anal at all - a very useful explanation.
Post #279348 4th Nov 2013 1:19pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
If you don't need a lift ....another vote for stanard LR springs and Koni or Bilsten Dampers....
N.
Post #279352 4th Nov 2013 1:41pm
