Home > In Car Electronics > What sub is this?
mcma1
What sub is this?
Post #278760 2nd Nov 2013 11:30am
Likeomg
looks like a alpine SWE-1200
have one in mine along with focals... sub is ok, can't compete with the focals... considered selling it actually but never got around to changing it out
Post #278761 2nd Nov 2013 11:33am
barbel jim
unfortunately none of the slim actives can compete with decent speakers, but paired with standard LR speakers will benefit the sound tremendously. Depends on your genre of music, loudness and how you have it set up. I have fitted a few and had the Alpine 1000SWE (earlier model). Branded models are all pretty similar, but the cone size alters...... personally I would go for an 8" speaker as should offer a better range.
Post #278777 2nd Nov 2013 12:46pm
2 GOS
Can you tell me where land rover put the amp and remote for this sub? Pictures appreciated. Thanks.
Post #367276 26th Oct 2014 5:48pm
There is no external Amp as an active sub means it's combined in one unit.
Only a passive set up is a Sub and Amp in separate units.
Can't comment on the remote, do you mean remote turn on wire or the idipendant bass contol? (If they have one)
Post #367298 26th Oct 2014 6:39pm
redzob
Guernsey 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
I fitted my Alpine SWE-1200 as an aftermarket, along with Focal speakers. Mine definitely came with an amp (now located under the cubby, which I wanted to raise anyway to provide a better armrest) and the remote is velcroed to the front or said cubby. Defender Puma 2.2 XS 90
Vespa GTS 300
Way too many racing bikes.
Post #367299 26th Oct 2014 6:49pm
2 GOS
Many thanks. Did you have to raise the cubby or would it have fit without being raise?
Post #367315 26th Oct 2014 7:26pm
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
The unit from Land Rover is different to the off-the-shelf model as the amp is combined in the casing with the sub making the unit slightly "thicker". The decal is also rotated Whistle Tom
@tditomprice
100” Defender Hybrid
2010 Alaska White 90 HT
Post #367317 26th Oct 2014 7:38pm
2 GOS
Not what I wanted to hear but thank you.
Post #367327 26th Oct 2014 8:07pm
redzob
@ 2GOS - I don't think the standard one would have been high enough as standard and was raised in the usual high quality way by LR using wooden battens. I bought the ExmoorTrim cubby that matched the rest of my XS interior and made 4 x 75mm spacers to get both the height I (and the wife!) wanted and enough breathing space for the amp. One of the other posts rightly pointed out that the Alpine logo is upside down - bit annoying.... Big Cry
Incidentally - apologies to the other posters as I didn't realise the standard LR version had an integrated amp. All the aftermarket ones do. Defender Puma 2.2 XS 90
Vespa GTS 300
Post #367345 26th Oct 2014 8:45pm
