- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Off Topic > Has anyone brazed rear dropouts? Propane or acetylene? |
ZeDefender
Cheers - then I only have 3 problems remaining:
1) I'll need to make up new plates (as suitable ones are impossible to find for such a tandem) so I'll have to buy the right grade (hard enough) plate steel - any suggestions?
2) Will it really be strong enough to weld edge-to-edge (4mm thick)? Wifey and I aren't exactly light
3) Oh, how I wish there was a local engineering works around here - "hit-and-miss" sounds like good odds when trying to find a good welder in this part of the world. Problem is, I want a really neat job done...
If the answer to 2) is definitely "yes" and I can get decent plate, then I have a very clear plan of action Tell someone you love them today because life is short.
1st Nov 2013 1:28pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
