Home > Off Topic > Good drill bits?
shaggydog
Good drill bits?
Hello Everyone,
Looking to find some decent drill bits.
Bought a very expensive set of Bosch drill bits from B&Q (the titanium coated ones) and they struggled with opening up a 7mm hole to 8mm in some 2mm steel using a drill press.... not impressed.
Does anybody know of a supplier/manufacturer of good quality drill bits?
They seem incredibly difficult to find.
Thank you in advance!
Dog
Post #272768 10th Oct 2013 4:07pm
Not suitable for all purposes but have you ever tried a step drill bit? I find they are excellent little bits of kit. No Guts, No Glory.
Post #272771 10th Oct 2013 4:18pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Try Dormer, Presto, Sherwood, Heller HSS and use a cutting compound
Post #272773 10th Oct 2013 4:30pm
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
Machine mart do a good set - Ti Nitrate coated which I use in my milling machine and lathe without issue.
Agree ref step drills for sheet. My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #272777 10th Oct 2013 5:26pm
Generaldej
United Kingdom 2009 Defender 110 Puma 2.4 CSW Alpine White
I got a box of 170 drills from Axminster tools - 1.0 to 10.0 in 0.5mm steps. Used on most metals including stainless steel but you must use cutting fluids to ensure longevity.
Post #272779 10th Oct 2013 5:42pm
Alex1976
Has anynoe tried a set of those drill bits that you see the guy selling at most of the LR shows. Drills all materials and guaranteed not to break.
I have a set of Heller HSS from Machine Mart and they seem good.
Post #272781 10th Oct 2013 6:08pm
GUM97
^^Yep I've got a set from the bloke at the Landy shows- great bits! An engine to TDi for!
Post #272784 10th Oct 2013 6:34pm
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
We Have 3 sets of heller one imperial 2 metric. Apart from snapping the smaller ones in pistol drills by being rough we have not had any problems also our local ironmongers sell them separately which is good. Rhubarb and custard let fly with their secret weapon.
Post #272794 10th Oct 2013 7:27pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
We use guhring drills or dormer for drilling all types of metals inc. stainless steels. Try J W Tooling based in Southampton for supplying them.
Post #272811 10th Oct 2013 8:43pm
shaggydog
Thanks Guys!
A britpart steel mud flap bracket should not defeat a drill press...
Will have a look tomorrow!
Post #272829 10th Oct 2013 10:18pm
madrunner
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Santorini Black
I use cobalt bits which have always drilled everything I've ever needed to pop a hole in.
Good oil makes a huge difference - I use rocol. Awesome stuff.
Post #273005 11th Oct 2013 7:35pm
bear100
Try Hilti awesome kit
Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #273026 11th Oct 2013 8:57pm
WarPig
I need a decent set of masonry bis, any suggestions please?
Post #277332 27th Oct 2013 8:07pm
AWOL
DeWalt bits in a SDS drill seem to go through pretty much any masonry like a hot knife through butter.
Not sure if it's true of all SDS bits, but they seem to last MUCH better than any bits I've used in a conventional percussion drill.
Incidentally, for anyone interested in Cobalt bits for metal, Toolstation do a useful Heller set for about a tenner. I use then, run fairly slowly to avoid excess heat and with oil, on stainless parts for my other car and have found them to be really good.
Post #278505 1st Nov 2013 8:14am
AndrewS
We spend day after day drilling steel/ally and concrete. So from experience Dormer for steel and ally, Hilti for concrete.
Post #278515 1st Nov 2013 8:44am
