Home > Maintenance & Modifications > Loom LR005920 for Defender towbar wiring?
Pickles
We will be taking delivery of our 90 in 10 days or so.
We are having the Landrover towbar fitted, different to the item you U.K. guys use, to comply with Aussie "rules"!
But in our '13 defender brochure, for the wiring, it lists a loom p/n LR005920, which simply plugs into an existing plug in the rear wheel arch,..... just plugs in.
Is this the loom that you guys use, or do you splice into existing wiring somewhere else?
Cheers, Pickles.
Post #278169 30th Oct 2013 10:00pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
I have just looked a TOPIX and it looks like the wiring should be in place with a sealed cap on the connector.
see: http://topix.landrover.jlrext.com/topix/co...tabs=false BM52
Post #278185 30th Oct 2013 11:07pm
Pickles
Yes, that is on the vehicle, but you need a loom to connect that lead to the towbar.
Cheers, Pickles.
Post #278198 31st Oct 2013 1:56am
don't be tempted to buy a non-LR loom, the OEM one is very well sealed. Just plugs in, takes 10 mins to fit Thumbs Up
Post #278209 31st Oct 2013 7:08am
bm52
see here for the loom
http://www.land-rover-parts-shop.com/en/ui...&stp=s
As BP says, I have also been advised to buy only a genuine loom.
hope this helps BM52
Post #278235 31st Oct 2013 10:11am
If you're having the LR towbar fitted from new, won't it come with the appropriate electrics as part of the kit? Confused Darren
Post #278316 31st Oct 2013 4:52pm
bm52
mine didn't, just had the tow bar....but i did buy mine at 4 months from someone who had to leave the country unexpectedly for a new job so i don't know the full original order details BM52
Post #278323 31st Oct 2013 5:06pm
