Home > Maintenance & Modifications > Rear seats into the back of a puma 90 hard top |
238kirk Member Since: 03 Nov 2012 Location: Doncaster Posts: 233 |
The guy who makes the panels is called Pete measures, he's based nr Melton Mowbray, I bought a pair a few months ago and they are excellent quality and a doddle to fit, heres my build thread http://www.defender2.net/forum/topic16619-60.html
You can contact him here pmeasures@hotmail.co.uk |
29th Oct 2013 7:27pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2751 |
Hopefully this is helpful
http://www.defender2.net/forum/topic16619-60.html Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
29th Oct 2013 8:52pm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2638 |
very helpful, so basically if i don't wan't to cut the tub all i have to do is space the bottom up?
does anybody have any photos that may help with installing proper seat belts, would prefer proper over lap belts... |
30th Oct 2013 8:35pm |
I've got seatbelts fitted to the rear of my 110 utility, not done by me but previous owner. Don't think they're original but they're 3 point and fit through the correct hole in the trim so obviously a very similar setup to the originals.
If you'd like ill take some pics Friday when I'm home if you think it'll help Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
30th Oct 2013 8:40pm |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
They come with an inertia reel 3 point lap over belt which has 2 locking points
30th Oct 2013 8:52pm |
yeah it will help, it will give me a general idea of what i need...
chers |
ill maybe take you up on that, mine is currently carpeted sides which wouldn't require much modding... ill let you know
check your thread on the windows ive photoshopped it (not my best work...) |
30th Oct 2013 8:57pm |
you can see the seat belt configuration here
30th Oct 2013 9:03pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
CSK..killer90 makes and fits them |
30th Oct 2013 9:07pm |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2891 |
Here some pics, the only mod needed is to the hinge point on the bracket, take the sping out and undo the bolts, re drill it and then back together, then add a hard rubber spacer, I then used a grinder to notch this out a little at a time until the seat came to sit level. The seat belt bracket attachs on to existing points. I used the load mat to position the bracket. We bonded and sealed basic fabricated plates on the underside and bolted through these.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
1st Nov 2013 6:29pm |
aha, i like. any chance if you have a moment, get a pic of what you did to strengthen the underside?
1st Nov 2013 6:40pm |
EDIT> See further down for a better pic
cheers, Last edited by Likeomg on 4th Nov 2013 9:31pm. Edited 1 time in total |
4th Nov 2013 9:20pm |
What do you need to know mate?
4th Nov 2013 9:27pm |
better highlighted here, does anybody have the part number for this bit? guessing its the bracket for the seat belt..
Click image to enlarge |
4th Nov 2013 9:30pm |
