Home > Puma (Tdci) > Frustration Greasing my shaft |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17504 |
You usually only need to unbolt one end, provided you can rotate the shaft.
However since you need to unbolt one end to articulate the joints fully and apply full movement to the splines you have to do this to grease the shaft properly anyway. |
30th Oct 2013 6:44pm |
Jonno Member Since: 06 Mar 2012 Location: Yorkshire Posts: 234 |
Good idea, i'll give it a go removing one end only.
Jonno |
30th Oct 2013 7:23pm |
MD5 Member Since: 02 May 2011 Location: Italy Posts: 143 |
This very cheap mini-grease-gun will allow a proper shaft greasing much easier than standard size grease gun (manual or pneumatic).
The supplied alloy tube, thanks to the small size perfectly fit to any nipple of the front and rear shaft. |
30th Oct 2013 7:55pm |
