Home > In Car Electronics > Anyone tried this? 12v battery powered heater with timer |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
http://www.sharperimage.com/si/view/produc...ter/200867
Any opinions? Could be the cheap(ish) solution for us <07 owners? |
28th Oct 2013 7:48pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Linky no worky!
29th Oct 2013 8:46pm |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
Works fine on iOS
29th Oct 2013 8:48pm |
My bad,have to wait longer than normal.Don't know if it's any different to the ceramic heaters you can buy over here and they don't get much good reviews.Anyways it says, " item sold out, no longer available".
29th Oct 2013 9:24pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4790 |
Two 160w heaters!?!? You can kiss goodbye to your battery after using that every morning for a week! 2002 90 Td5 Station Wagon
30th Oct 2013 5:30pm |
I've looked at those tiny 150w cheap unites with extremely poor reviews, I wont even bother...
Toying with the idea of a second battery at 100ah, 1200 watt hours / 300w = 240 minutes per charge. That should give me 20 ice free mornings assuming 300w of heat will deice and demist in 10 minutes. And I've just seen you can get 300w heated screens for around £160 |
30th Oct 2013 7:48pm |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 |
there's a little voice in my head saying that the manual will state "operating conditions: +5 to +25 °C"
My 2Kw (heating power, not absorbed energy) airtop takes 10min to demist the 110 on a cold morning, let alone de-icing. (no direct airflow to windscreen) The 6kw thermotop takes about 20min to de-ice (yes i know it has to heat the coolant first) My heated front window takes 5 minutes to form a water layer between ice and window so it can be removes easily from the outside. what these small ceramic heaters are good at is being sold with 800% margin and eating your battery while coughing some +2° hotter air on your window (so -10 becomes -8 ) I think 160£ spend on an old beagle or retriever to put in front of your window is money better spend, at least you'll get some love back and you'll be still able to start the car. |
30th Oct 2013 10:00pm |
steveyorks Member Since: 08 Apr 2013 Location: west yorkshire Posts: 183 |
I managed to get a second-hand webasto diesel fuelled heater for my tdi...awesome bit of kit It feels like having a fan heater in the cab.
11th Feb 2014 8:47pm |
+1 for a second hand Eberspacher/Webasto. I've got a D1 Eberspacher for a very good price and along with a cheap timer from the bay of fleas sorts my motor out in about 15 to 20 minutes without me leaving my house untill it's ready!
11th Feb 2014 9:06pm |
