Home > Maintenance & Modifications > Landy Glass Trim
mcma1
Landy Glass Trim
What way do you trim the inside of the landy glass kits?? How much does a set of county trim panels cost for the sides and rear quarters? Are there other options?
Thanks
Post #277948 29th Oct 2013 11:35pm
Cheshire110
I've seen examples where the standard trim has been used, looks good but there's a bit of a gap between window and trim, but not an issue really.
The window looks bigger since there is no metal casing around the window. but I think that's actually a good thing as visibility is better.
I bought some trim for my old 90 and they were about £100 on eBay if I remember, 110 ones are more common since most 90s are hard tops and have no trim in rear. Cheers, David
Post #277950 30th Oct 2013 12:03am
La salle is another option as you cut your own size
Post #277953 30th Oct 2013 4:46am
GUM97
Mine's left like this at the moment...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  An engine to TDi for!
Post #278049 30th Oct 2013 4:17pm
Brand new trim is approx £500
Post #278055 30th Oct 2013 4:48pm
