![]() | Home > Maintenance & Modifications > Build a trailer using 110 defender high cap tub |
dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173 ![]() ![]() |
Hi Guys,
I have been left out with 110 high cap tub after 110 SW conversion couple of months ago. So now i want to build a trailer using my left out 110 high cap tub possibly with leaf springs. My current problem is that there is very little help and advice to build this sort of a trailer in my country (people use hardly any trailers here). I have seen some nice threads here with perfectly home made trailers but i guess if somebody can give me info (diagrams, instructions, parts required) to make mine from the scartch, that will be very usefull. Appriciate. Cheers ![]() Kind regards, Diluk |
lukev01 Member Since: 24 Mar 2012 Location: Bedfordshire Posts: 412 ![]() ![]() ![]() |
Have a look at the LR Series 2 club forum: a group of members built a superb one out of the rear of a Series vehicle
http://www.series2club.co.uk/forum/forum/i...473.0.html 1970 Series 2A 88" |
Stulios Member Since: 22 Jun 2013 Location: Wirral Posts: 22 ![]() ![]() |
Seen quite a few started from Wide Track Sankey Trailers. Even if you cant get a complete one, possibly look at how they are constructed and make your own out of similar parts!
I have just aquired a narrow track Sankey with a Hi-Cap tub allready on it. Over time I might widen the axle, cut in half and space out the wheel track and perhaps put a swan neck near the A frame to lower the ring height to make the tub travel level.
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861 ![]() ![]() |
You can get indespension units with the same pcd as a lr wheel.
