Home > Td5 > Td5 goes to limp mode |
Carlosbeldia Member Since: 13 Oct 2013 Location: Cartagena Posts: 43 |
I had same issue in my car and it was CKP sensor wires that goes from engine to ECU. Simply make new ones in shield wire and good to go, maybe one of the best things. Be careful, that problem goes up until car dies, then you'll have to call the tow....
27th Oct 2013 1:30pm |
J the tree Member Since: 15 Oct 2013 Location: Surrey Posts: 18 |
Thank you for the quick reply
How did you work out it was the wiring at fault? Just had a look inside the ecu and it's as dry as a bone no oil at all Jon |
27th Oct 2013 1:51pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Hi Jon
You say the end of the crank sensor looked a bit chewed when you replaced it, did it have a shim fitted ? I ask this as my 2001 TD5 had strange running problems that were eventually traced to the crank sensor not having the shim fitted. The indy put a new sensor plus shim in (there had been no shim fitted since it was new) and the problems were resolved. The symptoms on mine were that all power/revs were lost at 2200 rpm, below that it was fine. My guess is that if the sensor was damaged it is to close to the crank and getting a faulty reading. Part number for the shim is NSJ000010. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
27th Oct 2013 2:46pm |
Hi Bob, thanks for the quick reply
Just pulled out the replacement crank sensor and this one is fine with no damage. Still won't rev past the 2000 ish mark before the engine management light comes on and she shuts down. Think the damage to the old sensor may be a bit of cr.p in the bell housing that became Spun up up with the flywheel. Just changed the throttle position sensor too for good measure- no change. Luckily I do have a spare td5 110 that runs well to swap parts over with to test them-'just don't tell the wife |
27th Oct 2013 3:22pm |
Does sound like the problem I had except I did not get limp mode.
If I remember correctly the garage put a new sensor in and ran the vehicle and the same problem was there, They did not originally fit the shim as there was not one fitted on the old one. They tried the shim as a test and it resolved the problem completely - the new sensor showed no signs of damage without the shim either. May be worth the £7 or £8 the shim costs to see if it that simple ? I also think there was an LR service bulletin for this exact problem on TD5's. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
27th Oct 2013 3:34pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1419 |
The gap needs to be set to the correct tolerance so as the senser reads correctly. Caused me alot of headaches a few years ago on a cossie - it was missing a lug on the bottom pulley, was like it when I stripped it but after replacing every sensor was the only thing possible left Welded a new one set the gap and she fired up straight away. You just brought a load of memories back
27th Oct 2013 3:48pm |
My indy was doing a lot of hair pulling and head banging as well
They replaced as was when the vehicle went in so it was either like that since new or fitted incorrectly before I purchased it. They had tested everything out on diagnostics and nothing showed up. New injector loom fitted just in case, the previous one was only a month old and actually had a problem of some sort, and as a last resort before suicide decided on the shim and the rest is history. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
27th Oct 2013 4:00pm |
It was alot of ££££ and 2 weeks of my life I won't get back. Exactly the same, had been running sweet did a full strip and rebuild (lowered the compression) put it back together and nothing. No faults on diagnostics etc. Called in alot of favors and even had some 'Cosworth' engineers stumped
27th Oct 2013 4:10pm |
Really hoping it is as simple as a shim under the sensor- none was fitted when I removed the original one- landy was running lovely up until last Friday and now she won't rev past the 2k mark without the engine management light coming on and shutting down- would be pulling my hair out if I had any
Looks like its a slow drive down to Hunters land rover in Guildford to see what testbook says |
27th Oct 2013 5:53pm |
HansT Member Since: 25 Dec 2012 Location: Mariefred Posts: 173 |
It sounds that you have the same problem as I have had for a couple of months now. See my thread:
http://www.defender2.net/forum/topic22280-90.html Please let me know if you find a solution. Hans |
27th Oct 2013 6:02pm |
Jon, just so that you are aware, Testbook didn't show any crank sensor problems on my TD5 hence the problem they had sorting it out.
Also, if the old injector harness was full of oil there is a chance it has got into the ecu and caused damage - that will be expensive Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
27th Oct 2013 6:19pm |
Opened up the ecu- dry as a dry thing inside- no trace of oil anywhere. At a total loss as to why she won't rev without the engine management light coming on.
On a plus side got the heated seats working so I can sit in comfort whilst not going anywhere |
27th Oct 2013 6:29pm |
Ok bit of an update- got myself a hawkeye as have 3 td5 in the family so made sense.
Ran diagnostic check and fault code 3197 popped up- topside switch failure. What I'm guessing is the excessive oil in the loom has shorted the ecu. Couple of questions 1. Can I fit a discovery ecu as there seems to be more of them about. 2.Does any one have a good ecu in exchange for beer tokens in the surrey area Ps it's a 2004 defender with aircon etc Jon |
1st Nov 2013 1:48pm |
I had the same fault code on mine. Found a used ECU on eBay. Will be syncronised on Sunday. And I hope that this will be the end of my problems.
Good luck! Hans |
1st Nov 2013 5:49pm |
