Home > Puma (Tdci) > Clutch Advice Please! |
dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173 |
I have a 2009 puma and my clutch was changed when it was around 17k but now again i am getting this bad rattling i suppose from the clutch at 45k. Also i noticed sometimes it slips the 1st gear. So now i thought of changing the clutch p.n LR012199.
Since it has done less mileage for a new clutch kit replacement, could i just survive by swaping just the clutch only or should i replace the whole kit? Cheers. Kind regards, Diluk |
26th Oct 2013 4:43am |
Many thanks for your valued info Donald. Appriciate that! So i think i better off getting the whole kit.
As far as i know you need to buy the the plate, the cover which refers the clutch kit part no as LR012199. But then how about the bearing? Microcat says input shaft bearing part no.LR004390. Then another related part is clutch slave cylinder part no LR031455. Are they both related? Should i buy either just the bearing or the slave cylinder? Appriciate your replys. Cheers. Kind regards, Diluk |
26th Oct 2013 5:33pm |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 |
Replace the whole lot.
You only want to strip it once Chris 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
26th Oct 2013 6:03pm |
dondiddy Member Since: 13 Nov 2012 Location: Hamilton Posts: 224 |
Hi Diluk, Sorry for not replying sooner but I have been on holiday for the last couple of weeks so havn`t been near a computer. Sound advice from dieselhead as you really want to replace everything at the same time to avoid having to take it all apart again in the future when a reused part ends up failing.
12th Nov 2013 7:20pm |
