Home > Maintenance & Modifications > Led lamps
simonpuma90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Led lamps
Has anyone changed there sidelights indicators etc for these new original look lamps RDX and bolt on bits are doing
Post #275706 21st Oct 2013 9:39pm
landy andy
Yep. Fitted them to my Td5 90, have now removed them from that, and fitted to my Tdci 110 DC.
Very happy with them. Much brighter, good price, all the connectors, look original, (apart from reverse and fog, look abit bling)
Andy
Post #275709 21st Oct 2013 9:44pm
I think that is what Chris Killer90 has but I'm not sure on brand. They are LED for certain though. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #275710 21st Oct 2013 9:44pm
simonpuma90
Are the colours good as I have found some can look a bit pink not red
Post #275711 21st Oct 2013 9:47pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
I have them on my side lights and tail lights. They are brighter and very red.
I was following my own 90 [my wife was driving it] and they are much clearer than standard and money well spent IMHO BM52
Post #275717 21st Oct 2013 9:57pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
Slowly getting the kit.
Have the front sidelights, very good, could easily drive on those alone if desperation required it.
Have the indicators waiting for a relay, which will come next month. Fitted the earlier squareish LED fog and reverse, look a bit different, but very bright, especially fog.
Day time looks like the FOG is white light, but that's just a lie by the camera
Just got an LED worklight from someone on here, changed all my instrument lights to LEDs, interior lights are both LEDs. Next year, hopefully LED headlights Twisted Evil 1998 110 300Tdi White Hard Top
Post #275725 21st Oct 2013 10:11pm
simonpuma90
Post #275752 22nd Oct 2013 7:25am
landy andy
I've kept as standard. Clear on the front, and coloured on the rear.
All look good and original, many people have asked about mine.
Andy
Post #275754 22nd Oct 2013 7:30am
dondiddy
Scotland 1998 Defender 90 300 Tdi ST Nato Green
Another Thumbs Up for these lights as I have a set fitted and found them to be very bright with good strong colours. The main lights only need a couple of wires pushed into the connector to be ready to fit depending on whether you have a Tdi or Td5/Tdci as the wiring is slightly different between the two. The fog and reverse need the plugs fitting and you have to crimp on the terminals before they are ready to fit. Again not a very difficult job. The number plate light also needs a little modification as the bullet connectors that are fitted don`t suit the later wiring but again you can sort that out without too much trouble. Well worth the money imho!
Post #275771 22nd Oct 2013 9:19am
smb
I'm just waiting for my set to arrive so will let you know Thumbs Up
Post #275773 22nd Oct 2013 9:36am
Kitoper
Switzerland
Hello Simon,
I have the following set:
http://www.ebay.co.uk/itm/8-RDX-LED-STANDA...35c7802f52
all look original although much brighter. I agree with Andy Landy that the rear reverse light looks a little bling, but it gives more light that the original.
The set is complete and even comes with the led relay and instructions.
The switch took max 30 minutes.
Highly recommended
A pic of my trucks front lights.
https://www.defender2.net/gallery/albums/u...mage~6.jpg
Post #275800 22nd Oct 2013 12:31pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
I upgraded the rear lights to LEDs from Flatdog http://www.flatdoguk.com/search.asp?types=LIGHTING+%3E+LED
Worth it, the brightness is in line with new modern vehicles and you feel confident that people can see you indicating and breaking in direct sunlight. The colours are the same, don't let the camera colours trick you,
You'll need the new relay to manually adjust indicator speed. Also the polarity on my indicators were incorrect, I had to cut the wires and join them the other way around.
Old
New
Post #275809 22nd Oct 2013 12:48pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I've got a set of the RDX lamps was abit dubious to begin as I had a led number plate lamp which lasted all of about 5min, but these lamps are great nice and bright and don't let any water in!
Regards 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #275878 22nd Oct 2013 5:59pm
simonpuma90
Ok I think ill order a set up thanks guys Thumbs Up
Post #275949 22nd Oct 2013 9:47pm
