Home > Td5 > Mirror door hinge removal?
Hock
England 2014 Defender 110 Puma 2.2 XS CSW Java Black
My passenger mirror arm is a little loose and could do with tightening, looking at it i presume i have to remove the upper door hinge to get to it.
Does it fasten into a 'captive nut' on the door (welded on?) or is there a 'loose nut' behind that will disappear forever into landrover hell if I undid the screw from the outside without removing the door panel? Whistle
Post #274543 17th Oct 2013 2:36pm
mk1collector
If you take the door trim off and open the window you gan get to the nuts at the back of the top hinge. Just undo the two on the door side of the hinge itself and the hinge will swing out with the mirror attached with two screws from the inside of the hinge.
Hope that made sense
Ray
Post #274545 17th Oct 2013 2:44pm
Hock
right, so the nuts on the inside are loose, cheers for that Very Happy Not as a quick a job as I thought it could be then, one for the weekend Thumbs Up
Post #274548 17th Oct 2013 2:46pm
jst
yes nut on the door inside are loose. the ones on the bulkhead are captive, but it is best to undo the door ones. so you dont have to reset the position of the door.
loctite the arm bolts back in too. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #274549 17th Oct 2013 2:50pm
mk1collector
When you've taken the trim off close the door and then undo the hinge bolts so the door doesn't need re-adjusting. When you've done the mirror just bolt it all back together before you open the door.
Post #274550 17th Oct 2013 2:50pm
