![]() | Home > Maintenance & Modifications > 4yr service question |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
48,000 miles for Diff and Tbox, 120,000 miles for Gearbox. LANDYWATCH
![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
so 48k miles whatever age and not 48 months then? is that correct?
thanks BM52 |
It just states the mileage. I had mine done at 2 years, B service at a main dealer. A full B service + oil change of transfer box! both diffs and gear box was £ 475 total. Also included both key fob batteries .
Is the £600 charge for the full B service including the oil change for the diffs and Tbox? If so I would look around. LANDYWATCH ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
yes and including MOT. Main dealer supposed cheaper price for retaining slightly older vehicles.....hmm BM52
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
![]() Click image to enlarge ^ I'm sure you had this already but in case you didnt, here goes. If you have a CES near you, they're pretty good for supplying oils etc. Just serviced my 110 for ~£80 when guy salmon quoted £350+VAT! Managed to get them to do a complete inspection for free when it was in because they kinda owe me one! Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 ![]() ![]() |
The glossary for the service sheet states the following:
It could be read either way. Every other item is serviced on a "which ever comes first" basis, so I don't think those oils will be any different. |
Unfortunately I'm pretty sure you're wrong there,
As far as I'm concerned, if it says 60k it means only at 60,000 miles. Otherwise it would say 60 month service Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 ![]() ![]() ![]() |
Agreed, logic suggests that the work is done at the mileage not the time stated...
Cheers Simon Ps My TD5 has only done 29k miles, and it's 12 years old, so I don't have specific evidence either way ... ![]() |
Since it's out of warranty, it's down to personal choice. My car probably won't be due a gearbox oil change until it's 18 years old (based current annual mileage), but I wouldn't be happy having 10 year old oil lubricating my gearbox, nor would I be happy buying a car that hadn't had an oil change in 18 years.
There are more factors that come into play than mileage, oils, belts, tyre etc. all age due to humidity, oxidisation and temperature cycling. |
To be clear, I meant the logic of the service sheet. I was just trying to confirm the meaning of what the service schedule stated.
I agree that changing oil more regularly is a good idea. I believe that oil can degrade with age, as well as use. cheers Simon |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
I agree with mark. Everything deteriorates in time.
Albert s Member Since: 20 Oct 2013 Location: Nth lincs Posts: 41 ![]() ![]() ![]() |
Does the service sheet cover the 2.5 TDI ? |
There are separate service sheets for different models and model years. I used the link here as a guide for my 300tdi. I think the dealer labour rate is the same for all older vehicles, just the time spent and consumables will be fifferent.
http://www.4x4network.co.uk/pdf/def-300tdi.pdf I have had a looked locally for an alternative price, local indie inc MOT about £485 -£500. No loan car. Main dealer £600 including MOT, 2 day loan car, warranty check/repair on paint and more convenient. So.....i will use the main dealer BM52 Last edited by bm52 on 20th Oct 2013 10:04pm. Edited 1 time in total |
My local dealer is doing two years for £670 including mot.
