![]() | Home > Td5 > Front air vent flaps |
DRW58 Member Since: 23 Feb 2013 Location: Perthshire Posts: 167 ![]() ![]() ![]() |
Hi I took mine off in the Summer and found the mechanism was seized making them difficult to open or shut.
Mine have the foam seals and even once sorted still allow some draughts through, but what a difference. It's easy but fiddly to do, just use plenty penetrating fluid to loosen the moving parts, the hardest part was putting the bolts back into the back of the flap....if I dropped them once....say no more!!!! Hope this helps DRW I built a garage for my Mini With a place for everything and everthing in its place. Ten years down the line there's a Mini in there somewhere, and ![]() |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5800 ![]() ![]() |
Check hinges are straight and not bent, make sure bolts through bulkhead and vent hinges are free moving.
Thy seals should be rubber and attached to the flap not bulkhead, that's the older ones, and if changing, main dealer parts only. Andy |
This /\/\/\ I replaced the seized, rusty vent pins wi stainless jobbies, pita to get the olds ones out tho.
Papa Lazarou Member Since: 11 Sep 2013 Location: West Midlands Posts: 40 ![]() ![]() |
Ok, thanks
![]() When I push the levers fully up to close the flaps, there is some resistance there and they bounce back down without locating in the notch. It's difficult to describe but it's kind of a soft squashy resistance, which is why I suspected the rubber seals. Maybe bent pins or hinges could give the same effect though? |
SGoggin Member Since: 04 Jul 2009 Location: Australia Posts: 19 ![]() |
When my TD5 was new, the dealer fitted Series 3 Rubber vent seals to the flaps to fix a leak in the roof... (Well they tried at least.)
But the problem with these seals - for me at least was that they were way too fat, and the result was the flaps would not latch shut. They tried bending the hinges to make them work - but they were just to hard and fat to fit. In the end they ripped the rubber seals off and replaced them with the correct flat foam seals that stuck to the vent flaps. They have been there for 10 years and worked perfectly. The roof still leaks though... |
Mine had the same symptoms of not latching on the top notch and as said by jimbob the pins were rusty and seized. If you open the flaps and look underneath there are two 10mm bolts. Undo the bolts and lift the flap manually while spraying lots of wd40 on the pins and work the flap up and down for a couple of mins. After doing this mine closed easily.
Cheers, I'll give that a go then
![]() Failing that, how much of a PITA was it to remove the old pins and replace with stainless jimbob? It'll either be doing that or replacing the rubber seals with the foam ones as suggested. |
Mine were bad, took me over 3 hours to get them out,I think
![]() Also used a pair of mole grips to try and turn the pins but didn't work initially so just kept spraying more lube into it,you may also need a suitable sized drift to help knock the pin out,especially when the pin shears at one end whilst using mole grips ![]() The new stainless jobbies popped straight in. |
That doesn't sound like much fun
Definitely need plenty of lubrication, you certainly don't want sticky flaps...or so I hear
![]() ![]() ![]() ![]() With a place for everything and everthing in its place. Ten years down the line there's a Mini in there somewhere, and ![]() |
Took the advice on this thread and got it sorted
