Home > Puma (Tdci) > Pumas 2.4 TDCI Engine timing chain change
Magnimike
France
Hi
Can anyone tell me at what milage the timing chain and tensioner on a 2.4 TDCI Puma engine, should be changed Question Tks
Post #273127 12th Oct 2013 12:52pm
Glynparry25
SHouldn't need changing- that is the bonus of a timing chain over a belt Thumbs Up Just change if there is a problem.
Glyn Dog Sheep
Post #273129 12th Oct 2013 1:11pm
JR
Scotland 1984 Defender 90 200 Tdi SW Coniston Green
don't have a specific answer beyond the fact that timing chains don't normally get changed as a matter of routine.
Post #273130 12th Oct 2013 1:13pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
As Glyn says Thumbs Up
We do a few on Transits, once they sound 'rattley' or have the associated starting issues .... but rarely see this until about 125k - 150k Guns and Landrovers .... anything else is irrelevant.
Post #273131 12th Oct 2013 1:15pm
Magnimike
France
Thanks all
Good news, I am still a bit of a Land Rover Virgin at the moment !
Post #273142 12th Oct 2013 2:07pm
munch90
No way would I leave a timing chain 125k .. Or wait for a problem I don't think so .. Ratchet mech in tensioner wears chain then jumps on inlet cam . If your very very lucky they break bolts on rocker shaft or not so lucky the bolts rip out out of head normally cracking where the bolt goes in
Good oil and changed regularly helps but after doing chains and seeing the damage I will not be taking the chance
There not bad to do and not a fortune ... To be honest I would rather do a tdci chain then 200 or 300 belt
Post #279814 5th Nov 2013 7:57pm
Whitewaitress
We changed ours at 95k when we replaced the head gasket (2.4tdci) - the tension difference was noticeable although not significant between the old one and new one. Bit tricky to re-set if you have to remove it at all if the chain isn't perfectly aligned!!
Post #285554 26th Nov 2013 10:23pm
