Page 581 of 1380 <123 ... 580581582 ... 137813791380>
JWL
Hardwired my el-cheapo heated seats into some switches on the dash console and now opened a whole can of worms on other switches I've previously put in. I knew I shouldn't have tried to rush it, damned school runs! Still a job for Saturday along with replacing the abs shuttle valve solonoids that arrived today. Hopefully that will sort out the re-occouring illumination.
Post #272770 10th Oct 2013 4:12pm
shaggydog
Replaced my mud flaps with new ones (re-tapping rivnuts on the front is weirdly satisfying) and started K-rust application to the chassis. Quite spectacular the difference really though need to grab some more….
Also lifted all the seats in the front and had a tidy up as the yellow seat foam dust was getting everywhere.
And sorted a few annoying squeaks with the application of screws or rubber sheeting.
Post #272772 10th Oct 2013 4:29pm
diesel_jim wrote:
Just loaded the 90 up ready to go out and do some lanes this afternoon. Marlborough/salisbury plain/Devizes area if anyone's about.
And did a nice BDR repair on the coolant pipe that decided to split open in the middle of nowhere. Still, managed to do 114 miles beforehand.
Had a gentle slow drive back home with the coolant filler cap loosely fitted so the system didn't pressurise and blow my bodge repair apart.
Think I'll be getting a new pipe tomorrow and possibly pulling the head off to see why it keeps pressurising the system
Post #272810 10th Oct 2013 8:40pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Nothing.
My wife has nicked it on the pretence she needs it for work Rolling Eyes
Last time she borrowed a car I didn't get it back for about 3 years Neutral BM52
Post #272928 11th Oct 2013 1:11pm
Generaldej
United Kingdom 2009 Defender 110 Puma 2.4 CSW Alpine White
Tried to fit the defender into the garage today so I could check the oil level. Everywhere else on our drive slopes in one direction or the other. Had to empty the garage as we don't use it for vehicles.
Where it ended up was on flat ground so I was able to measure the oil level anyway - after all that I didn't have to put any in Very Happy
Post #273003 11th Oct 2013 7:20pm
JWL
Did you manage to get the bonnet stay in position, that must have been close Whistle
Post #273045 11th Oct 2013 11:16pm
ericvv
bpman wrote:
Re-fitted my momo-nero from FCX Thumbs Up
Finished the 8700 evo installation, then took the ICE out in the dark to try out the new lights - very happy with the results ..
.... just need the 90mm spots replaced by LED spots now
Steve, seems easier said than done. Any ideas? You will remember a thread about exactly this that I started long time ago and which received several followers, including you, and also some encouragement from potential suppliers/site sponsors,.... but then it went quiet. Crying or Very sad
So seems not an evident thing to do. Guess the SVX style front is still a too limited potential market for companies like Speaker to engineer an easy fitting solution, even if they already do have 90mm high beam LED lamps in their assortment. Twisted Evil
Here is the link to the mentioned thread. Guess more people would be interested, so maybe we have to revive it....
http://www.defender2.net/forum/topic16121....lights+led You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #273058 12th Oct 2013 5:45am
I am assured its work in progress Wink
Post #273065 12th Oct 2013 6:31am
ericvv
Post #273071 12th Oct 2013 6:47am
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Finished bedding her in Cool
Post #273206 12th Oct 2013 8:00pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Brilliant...mine is just freeing up after a little under half that mileage!
Post #273209 12th Oct 2013 8:03pm
Tiger
Took the rear sets out
Post #273211 12th Oct 2013 8:04pm
JWL
Mine just went over 160k yesterday
Post #273219 12th Oct 2013 8:17pm
mk1collector
Picked up the bits to make my own side window demisters, just need dry weather now Rolling Eyes
Post #273227 12th Oct 2013 8:34pm
Nobby
England 2010 Defender 90 Puma 2.4 CSW Santorini Black
Took out the twin USB socket, put back the land rover connector as the new Garmin Satnav wont allow the traffic to work with the hard wired TomTom one I had previously fitted. The connector is the same but it kept warning of incorrect cable, read the instructions and it seems it will only work with the cable in the box which only fits the original outlet. Evil or Very Mad _______________________________
Puma Defender 90
Post #273246 12th Oct 2013 9:46pm
