Home > Td5 > Remapping td5. Need more air.
pesto_trader
Norway 2005 Defender 90 Td5 SW Tonga Green
I tried remapping my Defender 90 td5 04/05 a couple of months ago. Was very happy for a while. Then remapper from Bell Auto Services made me aware of black smoke. We took off the centre part of the snorkel, but nothing changed. He checked the air flow meter, which was fine. I think he used a nanocom or something. And it says its peeking at 500. He said 600 is where you want to be. Any thoughts on this issue? Is the snorkel the problem? It was such fun driving a slightly faster and stronger Defender.
Thanks guys. Peter
Post #261514 26th Aug 2013 10:24pm
You can try removig the centrifugal fan thing that's inside the air box (it's on this forum somewhere), where the main intake pipe goes into the airbox, it's clipped in there.
Once you pull it out you'll need to seal up the small holes that are left (From the clips). Doing this made a little bit of difference on my 110.
Post #261556 27th Aug 2013 7:55am
Postmanpat
Ireland 2004 Defender 110 Td5 DCPU Bonatti Grey
would bypass the snorkel and see , its know that with a snorkeler you off-set some of the improvements ... Postmanpat
Post #261838 28th Aug 2013 11:02am
landy andy
Do test with the top off the air box, this will tell you if it is worth messing about with the intake system.
Andy
Post #261855 28th Aug 2013 12:07pm
Will.I.AM
United Kingdom 2005 Defender 130 Td5 HCPU Kaikoura Stone
try a induction kit like mine, it makes the biggest difference ever! i will put a picture into my profile now.[/img]
Post #261866 28th Aug 2013 1:19pm
bell-auto-services
Slightly low boost pressure can also keep the maff reading down!
Post #262412 30th Aug 2013 4:40pm
pesto_trader
Thanks guys! Hope i can fix this myself. Smile
Post #272686 9th Oct 2013 10:31pm
austinhealey55
2003 Defender 110 Td5 HT Chawton White
Does your Td5 have a catalytic converter? If so, it could be the issue of low MAF and turbo values, especially if you've done all the checks on the intake (cleaned intercooler, checked intake hoses, removed or checked EGR, new air filter, checked intake for blockages before air filter, have a known working MAF installed, etc.). Not all Td5s had cats though.
My '03 Td5 cat was totally blocked... and if the air can't get out, it can't get in either. I had low MAF values and lack of turbo pressure, and fixing this restored things to normal. You can check if yours has a cat by looking just aft of the front wheel, passenger side (on RHD). Yellow arrow points to it in the photo. Not a bad job to check/clean or replace it, can post more info about doing so if it'll help.
Cat as installed:
Downpipe w/ cat:
Post #275488 21st Oct 2013 9:16am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
out of intrest did you ever sort this?
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #294302 30th Dec 2013 8:00pm
