Home > Puma (Tdci) > Swivel Joint seal leaking
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Hi
On my car the LH swivel joit seal was leking oil.
I inforned my dealer as the car is just one year old. He now has changed the oil for grease. Is this normal?
Q
Post #272497 9th Oct 2013 9:17am
SteveG
2005 Defender 90 Td5 CSW Belize Green
It should have had grease from the start. I suspect what was happening is that axle oil was migrating past that seal into swivel joint and then leaking out on heat expansion through the swivel seal.
Post #272500 9th Oct 2013 9:22am
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
as far as i know LR changed to grease long time ago. Yours should not have oil in the swivels but grease. If there was an oily substance in the swivels you probably have you diff oil migrating past the seals into the swivels. (seal part nr FTC3276)
In short, your grease will be oil again after some time. Did they check diff oil level? might be worth looking at it before the diff is "running dry".
2cents
Thumbs Up
Post #272501 9th Oct 2013 9:27am
