Home > Maintenance & Modifications > Ramps – what do you use? |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1385 |
Why not use axle stands ? Putting Dreams on Drives at JLR Solihull..
7th Oct 2013 3:33pm |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
I have a pair of old ramps that I got from a car parts shop years ago, although hardly ever use them.
For prop greasing I find I can get underneath quite easily (and I'm a good 90kg, so not a lightweight..!). It probably helps that my garage floor is a nice smooth epoxy coated finish that I can slide on. For any other work (like when I Dinitrol'd the underside) I jack it up on 4 axle stands (3T ones). In my dream garage, I'm planning a lift, just not sure on 2 or 4 post.. cheers simon |
7th Oct 2013 5:36pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6103 |
There was a set of mega ramps on here for sale a month or 3 back, like they have outside car dealerships with the *special* car is parked up on it. gives you about 3' clearance.
I just use a crappy set of ramps, but fairly HD ones (found them chucked in a layby in Portland some years back) and they were far sturdier than my old halford type ones. As couplands says, for greasing the props I just usually lay underneath, either on an old sheet/blanket/bit of carpet, or use my roller lay on thingy, but as we've got a fairly rough tarmac drive, on a slope, it's a bit of a pain to use that for any length of time. For doing the props, I jack one wheel /just/ off the ground, so i can rotate the prop and get to all 3 nipples |
7th Oct 2013 5:50pm |
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 |
We use a mobile ramp
Click image to enlarge William |
4x bits of railway sleeper or a kerb stone. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to us off. Richard |
7th Oct 2013 7:38pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
@william8 - that is cheating but quite cool
@ARC99 - kerbstone - confused BM52 |
7th Oct 2013 7:53pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Generic 2 tonne ramps, as others have said you can slide under quite easy to do most jobs without lifting it.
7th Oct 2013 10:33pm |
jont Member Since: 02 Apr 2011 Location: Aylesbury, Bucks Posts: 242 |
Saw some handy looking ones at the Peterborough show - quite high and heavy duty with a detachable platform on the side that you can stand on as well ... were about £100 from the stand next to Raptor ...
Jon |
7th Oct 2013 10:48pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6308 |
'For doing the props, I jack one wheel /just/ off the ground, so i can rotate the prop and get to all 3 nipples ' aren't there 4 (2 on each) ? |
8th Oct 2013 6:12am |
3 per propshaft, 1 on each spider and one on the telescopic slider.
8th Oct 2013 6:34am |
