Home > For Sale & Wanted > FS Exmoor Trim Seat Risers
buellbeast
2013 Defender 110 Puma 2.2 XS CSW Orkney Grey
For Sale
Exmoor Trim seat riser new in box as sold HERE for £75 + vat + carriage
The seat riser gives you extra legroom and more comfort. These adjustable risers are installed beneath your existing seat runners and allow you to tilt and adjust the seat to your desired position by adjusting the height and rake of your seat.
The seat riser will create more space between the steering wheel and seat back which makes this product ideal for the taller driver. Its substantial powder coated steel frame allows you to mount the seat runners forwards or backwards in three different locating points.
The seat riser is easy to adjust by releasing the bolt clamps (two on each side) and setting your seat into one of its 21 new position and then bolt lock into place.
This can also be used with centre seats or cubby boxes fitted.
£60 delivered
Post #223358 30th Mar 2013 6:54am
buellbeast
No sensible offer refused Whistle
Post #271750 6th Oct 2013 8:00am
